Did i just mess up my new tranny?
So i think this happened on my way home from the guys house. Isnt this a seal for the shift linkage? And if its bent like that will it leak? How hard to fix this??
I just bought that seal from Honda (along with the other four) the other day.It was about six or seven bucks.Pops in and out pretty easy.
So i can just grab it with some pliers or pry it up with a screwdriver? Which other four seals are there? Might as well replace everything i can so i know it wont leak anywhere
Yes.That one is easy as long as the case isn't dented too.I'm doing a tranny freshen up.The other seals are the pass side axle,midshaft(drivers side),and input shaft seal.The tranny needs to be disassembled to do the input seal.The axle and midshaft seals are fairly easy to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK »</TD></TR><TR><TD CLASS="quote">I expected to see a "new" tranny after I read the thread title... </TD></TR></TABLE> It's new to him
Yeah it is new to me lol. I was reading a write up and it said you had to push those axles seals out from the inside? Will those just pry out also? Do those have to be pressed in?
