Type R Oil pump and water pump on a LS. Timing Belt?
Old Apr 14, 2008 | 03:16 PM
Justintegra's Avatar
Default Type R Oil pump and water pump on a LS. Timing Belt?
Ok I'm building an LS (B18a) motor for turbo, I have a Type R/GSR water Pump and a Type R oil pump. Now I know the water pump has 22 teeth and differs from the LS water pump. I started the motor with a GSR timing belt and the timing belt almost jumped a tooth Cut off the motor...I'm lost. Yes I have a new tensioner and Yes I've searched I'm getting conflicting results. Some say you have to use the GSR timing belt and some you can't use the GSR timing belt. HELP!!
Modified by Justintegra at 4:21 PM 4/14/2008
Old Apr 14, 2008 | 05:13 PM
Default Re: Type R Oil pump and water pump on a LS. Timing Belt? (Justintegra)
Oh come on someone has to know!!
Old Apr 15, 2008 | 01:04 PM
Wow this forum is lame....
Old Apr 15, 2008 | 01:09 PM
soulpwr's Avatar
You need a GSR timing belt
Old Apr 15, 2008 | 01:34 PM
NAmodified's Avatar
Default Re: Type R Oil pump and water pump on a LS. Timing Belt? (soulpwr)
no bro ur lame.
all b series oil pumps are interchangeable. That means the itr and the ls use the same pump.
if you change your water pump to a VTEC water pump then be sure to change the timing belt to a vtec belt.
vtec= gsr, itr
non vtec = ls, rs
if you use an ls, rs water pump, then use an ls,rs timing belt.
Old Apr 15, 2008 | 04:10 PM
g2daturbo's Avatar
Default Re: Type R Oil pump and water pump on a LS. Timing Belt? (NAmodified)
match the belt with the pump ls pump ls belt gsr pump gsr belt, be sure to put tension on the belt by pushing on the tensior with a pry bar or something of that sort...!
Old Apr 15, 2008 | 04:13 PM
akandok's Avatar
Someone already answered this, but here is a simplified version.
Match the water pump with the same belt.
LS Water pump = LS Timing Belt
ITR - GSR Pump = ITR - GSR Belt.
Old Apr 18, 2008 | 05:30 AM
gsrcrazy's Avatar
yup.. oil pumps are the same.. and
like akandok wrote..
Old Apr 20, 2008 | 11:59 AM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (gsrcrazy)
oil pumps "above" 96 are all the same
Old Apr 20, 2008 | 12:46 PM
hmongyaj87's Avatar
and they are not type r oil pump. just gsr oil pump.
shortyz21
Nov 12, 2006 08:38 AM
1slowcrx
Nov 17, 2004 03:24 PM
lsvtechatch04
May 8, 2004 03:20 AM
JR Integra
May 3, 2004 04:17 PM
vtecb20coupe
Dec 10, 2003 12:15 PM
