speedometer not working after engine swap
Hey guys, my friends and i just took out my gsr motor to rebuild and just put an ls in for me to drive...well after we put the motor in the speedomter isnt working, we thought we forgot to plug the sensor in, checked that and its def plugged in, what could be the problem? maybe the conector has dirt inside?....oh and the odometer and cruise control are not working as well, i am still running an obd 1 gsr ecu, because i'm still waiitng on getting an ls, not sure if that would affect anything. any info would help, thanks alot
hey obd11 i have a n4 integra i recently last summer swapped my b16 for a b20 i have the same problem, if you get any information on the problem let me kno plz
so I found out the problem. I looked under my intake manifold and I found that my speed sensor was slightly loose, I just put a Lil effort into pushing it in and it all started working again. Speedometer and odometers and the cruise control was all working well after this.
noDoHoK
11
Dec 8, 2012 06:41 PM
