D15Z4 swap to B18C4 electrical problem
Hello.
I have had this problem:
I own this Civic
motor was D15Z4. I made a swap on B18C4. The swap is almost done, but I can not find pinout green chips, which is mounted on the computer. I need the pinout of this chip from the motor D15Z4 because other D15 is not the same.
I would be grateful for your help.
I own this Civic
Re: D15Z4 swap to B18C4 electrical problem
Are you sure that it's for d15z4? This engine with out vtec, was made for arabian countries
I have different connections from d15z8 engine
If you loved me, you'd all sell me your magic cards to me today
That is for an OBD2A ECU, I am unsure what was available in Arabian countries, sorry.
OBD1 in North America also has 3, sorry I can not help you. Maybe someone else can chime in.
Can't find pin-out for these type of ECU. You will have to use the ECU and harness that matches the the new engine plus all the missing sensors on your car.
go to a junk yard get you a wireing harness out of a 98 ex coupe most all the connectors will plug right in to the obd1 connectors except for the injector plugs but u can use obd2 injectors they will work just fine only other thing u gotta do is make a plug for the intake temp sensor which will be by the dizzy cut off the black plug and wire in a round gray 2 wire connector and use and obd2 alternator should be all set
noDoHoK
12-07-2012 12:10 PM
