K-Series Turbo Oil Return Line??
Old Apr 14, 2008 | 07:17 AM
BIG T's Avatar
Default K-Series Turbo Oil Return Line??
So i am currently trying to figure out where the best place is to put an oil return line on my K20 although i am not 100% sure where the best place is.
On the back side of the pan but how high up and where??
Or is there is a better place to place the oil return bung?
Perhaps a picture would help if you have done this..
Thank You
Old Apr 14, 2008 | 08:16 AM
NJslvrtypes's Avatar
Default Re: K-Series Turbo Oil Return Line?? (BIG T)
every turbo car i put together, i put the bung here. no probs at all. you can also tap the lower block if the motor is torn down but the top of the pan is well above the oil level.
Old Apr 14, 2008 | 08:28 PM
BIG T's Avatar
Default Re: K-Series Turbo Oil Return Line?? (NJslvrtypes)
what size fitting is that
Old Apr 15, 2008 | 06:27 AM
done's Avatar
That is the exact place i put mine.
I used a -10an bulkhead fitting with bulkhead nut. then cut the back of the fitting off.
Old Apr 15, 2008 | 02:06 PM
1/2" NPT to 10AN
philcivicjordan
Welding / Fabrication
May 12, 2015 09:22 PM
Stopsign32v
Dec 17, 2010 09:35 AM
boriquabdygurl
Feb 18, 2007 07:04 AM
carbonDelSol
Jul 15, 2004 07:01 AM
b00stedsi
Jul 28, 2002 04:17 PM
