Coolant soaked carpet, WHAT IS LEAKING ???
Old Apr 13, 2008 | 08:30 PM
ben1284's Avatar
Default Coolant soaked carpet, WHAT IS LEAKING ???
have mad puddles of coolant on the driver side and pass side carpet under floor mat. The firewall pad, under gas, clutch and brake pads are soaked as well. What and where leak coming from? The 2 hoses that go out of the firewall (heater hoses) ??? My coolant level in the radiator and block doesn't really change and it does not over heat. If anything it under heats. wtf
Old Apr 13, 2008 | 08:52 PM
Hybrid96EK's Avatar
Default Re: Coolant soaked carpet, WHAT IS LEAKING ??? (ben1284)
heater core.
Old Apr 14, 2008 | 04:17 AM
ben1284's Avatar
Default Re: Coolant soaked carpet, WHAT IS LEAKING ??? (Hybrid96EK)
is that something an ave guy can fix or take into Honda? thanks
Old Apr 14, 2008 | 05:08 AM
GhostAccord's Avatar
It's something you could do if you are comfortable taking out the entire center console. I would suggest to take it to a shop if you do not have a shop manual or you don't feel comfortable tearing into your dash.
Old Apr 15, 2008 | 05:06 AM
IIXtremeHansen's Avatar
Heater core.
Old Apr 15, 2008 | 10:56 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Coolant soaked carpet, WHAT IS LEAKING ??? (Dickies_n_FlipFlops)
gotta remove the dashboard
Old Apr 15, 2008 | 11:33 AM
ChinkyChris's Avatar
its not that bad to remove...if you want i think i have a diagram of where all the bolts are
Old Apr 15, 2008 | 01:37 PM
ben1284's Avatar
Default Re: (*****yChris)
trying it tonight, shops want about 800 to replace it... I don't think so !!! Might need o take off intake manifold. That sucks more than the dash..............
thanks people............................
Old Apr 15, 2008 | 01:51 PM
Default Re: (ben1284)
lol..... yeah the Dash along with the entire center console, gauge cluster, glove box, Steering wheel and steering wheel support bar. If you think the IM is tough I think you'll be singing a different tune after this exercise.... It can be done, I just finished taking mine out now. 3hrs later and that's with the front seats removed. That's why it costs $800 at a shop. It's pretty time consuming.
Good luck and remember a little patience goes a long way on this job, Oh did you pick up a Honda Shop manual? That helps 100%
Ethylment
Honda CR-V & Element
Jan 20, 2013 07:59 PM
jvonb
Jan 10, 2006 03:30 AM
KanzenR95GSR
May 11, 2004 09:02 AM
Chrislow
Jan 16, 2004 01:49 PM
