91 integra GS gauge cluster removal NEED HELP
WHATS UP GUYS, I recently purchased a this car, and noticed when i turn the key forward the CEL light does not come on and shut off! I figure someone removed the bulb trying to hide the fact that it has some CEL codes. Any body ever removed one. I need some help, i broke some mounting hardware behind the vents on my accord when i tried to remove the cluster, I dont want to do this to the integra. DO the vents pop out exposing mounting screws? any help greatly appreciated.
Also want to check the ignition timing and have done it before on multiple other vehicles i know to jump the harness near the ECU , but there is no " window to the flywheel, are the marks on the crank pulley?
I am not looking at one right now but there is quite a few hidden screws you got to get to before it will come out. first off, no vents need to come off
Starting as I remember them left to right
one screw behind coin tray
2 screws in cluster area up top
one screw under the general area where the climate control is you have to pull the bottom plastic (where your legs sit) out using the final 2 screws that hold it in
2 screws behind climate control ****. pull **** and trim for air speed setting off then pry out the plastic that lights up at night
1 screw to the bottom right of the 2 center vents. its behind a small ribbed piece of plastic.
then the dash trim should pull off and reveal the other 4 screws (i think) holding the cluster on
the timing marks are on the crank pulley
thanks so much, cause i really dont want to break anything this time! Once figure out what the codes are everything else will be easy!
stocker2shocker91
Aug 6, 2005 04:25 PM
hypnotic
Jun 13, 2003 10:44 PM
