Driver's Low Beam Not Working, Help!
Old Apr 13, 2008 | 06:04 PM
A's 94 GSR's Avatar
BG-33P
Default Driver's Low Beam Not Working, Help!
Alright I have this problem that I can't figure out. My driver's side low beam doesn't work, but the passenger's side low beam works fine. Both high beams and both fogs work fine also. I checked the fuse underneith of the dash and it was fine also. I swapped the bulbs and the bulbs also work. Why isn't my driver's side low beam not firing?
Thanks.
Old Apr 13, 2008 | 06:11 PM
db-1charlie's Avatar
Default Re: Driver's Low Beam Not Working, Help! (A's 94 GSR)
check the power distribution block. So check for power its self in the ground and then search for an electrical diagram and make sure those are not messed up either.
Old Apr 13, 2008 | 06:15 PM
A's 94 GSR's Avatar
BG-33P
Default Re: Driver's Low Beam Not Working, Help! (db-1charlie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db-1charlie &raquo;</TD></TR><TR><TD CLASS="quote">check the power distribution block. So check for power its self in the ground and then search for an electrical diagram and make sure those are not messed up either.</TD></TR></TABLE>
lol, come again? I'm not sure what you're saying here.
Old Apr 13, 2008 | 06:36 PM
silverAC's Avatar
use a meter to check for voltage. use the power and ground wire from the connector that plugs into the light. if you've swapped bulbs and the problem remained than you should have little to no voltage at this connector. then use the power from the connector but find ground somewhere else. if you have 12-14 volts or so this indicates a bad ground in the light harness. Run a new ground. If you still don't have good voltage, use the ground from the harness but use the + terminal of the battery and check voltage. 12-14 volts this way would indicate the light is not getting power. run a new power wire to the fuse box. the black wires are ground on the light connector. in case you didn't notice... there are seperate fuses for each headlight. did you check the right one? also i would use a meter to check the fuses, sometimes they look OK but aren't.
Old Apr 13, 2008 | 06:44 PM
A's 94 GSR's Avatar
BG-33P
Default Re: Driver's Low Beam Not Working, Help! (silverAC)
^I think I follow that.
Old Apr 17, 2008 | 04:01 PM
A's 94 GSR's Avatar
BG-33P
Anyone know where the Headlights ground to? I can't find it.
Old Apr 19, 2008 | 12:17 PM
A's 94 GSR's Avatar
BG-33P
I figured it out, it was a bad ground. Fixed her up and now she works!
Kirk Hoey
Honda Civic (2001 - 2005)
Sep 28, 2019 11:25 AM
eghatchin
16
Apr 25, 2008 04:46 PM
01-0720
Apr 14, 2006 06:30 PM
gsr-2nr
Jul 18, 2004 04:52 PM
acurint
Dec 4, 2001 11:03 AM
