HELP!!
Old Apr 13, 2008 | 03:16 PM
civic46's Avatar
Default HELP!!
ok so i got the motor in my race car...i had my head all ported adn polished adn i put it all together drop the motor in adn its a bitch to start and when it finally runs it idels for 10=15 seconds and quits or if i touch the gas it quits....whats wrong with this? kuz im [freak]in stumped!
thanks
Old Apr 13, 2008 | 03:23 PM
superfast666's Avatar
Default Re: HELP!! (civic46)
sounds like the map and tps sensor plugs are backwards
Old Apr 14, 2008 | 03:59 AM
civic46's Avatar
Default Re: HELP!! (superfast666)
nope not it anyone else got anythoughts im completly stumped thats for sure!
Old Apr 14, 2008 | 07:20 AM
civic46's Avatar
bump for some more ideas....im goin nuts i unno what is goin on!!! lol
Old Apr 14, 2008 | 07:39 AM
Rexwhippin33's Avatar
Have you adjusted your idle at all??? Do you have all solid connections???
Old Apr 14, 2008 | 07:41 AM
civic46's Avatar
Default Re: HELP!! (Rexwhippin33)
no i have not touched the idle at all since i didnt touch the intake when i took it off....altho i will check tonight when im off work....but why would it make it so when i touch the gas it dies?
Old Apr 14, 2008 | 10:25 AM
civic46's Avatar
anymore ideas guys/gals?
Old Apr 14, 2008 | 11:07 AM
wiZCo's Avatar
Stouts 'n' Scotch
Any CELs?
Old Apr 14, 2008 | 11:37 AM
civic46's Avatar
Default Re: (wiZCo)
none that is what i dont understand...lol...im so stumpped i cant even think bout anything else this is mind boggling! i just hope some one can help me out with it so its running my next satuday since that is first night! lol
Old Apr 14, 2008 | 11:38 AM
IT GUY's Avatar
Default Re: (civic46)
what motor in what car with what ECU?
Old Apr 14, 2008 | 11:41 AM
2slow4stock's Avatar
Are you sure the valve lash are fine? Check the injectors if there spraying. Check ignition. Theres lots to check but the main question as stated above is what engine and ecu.
Mason Fraser
Nov 15, 2012 04:59 PM
JDM-KIDD
Feb 5, 2011 01:04 PM
illestrolla247
Jul 10, 2009 08:55 PM
zeplin
Nov 9, 2008 10:57 AM
VTECth1s
May 31, 2006 05:26 AM
