carbon buildup on inside of IM????
Old Jul 11, 2002 | 10:03 AM
servion's Avatar
Default carbon buildup on inside of IM????
I took the top of my IM off today (JDM H22a, OBDI) and there was what looked like a bunch of carbon buildup... it had pretty much a hard, dry, black coating all inside of it. I am still working out the bugs of my motor swap and I am having some mean misfiring problems (wiring I believe), which has also caouse me to get around 19mpg for this tank. Maybe this im stuff is related?
Old Jul 11, 2002 | 10:13 AM
martini's Avatar
Default Re: carbon buildup on inside of IM???? (servion)
misfiring? Hmm, I don't know
Perhaps your intake valves aren't seating properly..
have you ruled out oil from the crankcase?
Old Jul 11, 2002 | 10:19 AM
servion's Avatar
Default Re: carbon buildup on inside of IM???? (martini)
Well, I did a compression test 2 weeks ago.. 202 202 192 202
I changed my PCV valve a week ago... and I don't have an intake hooked up on my car... but that is because I'm not driving it yet... just trying to get it to run right in the garage first
Would the fact that I don't have the tube from an intake to my VC hooked up cause this?
Old Jul 11, 2002 | 07:03 PM
whatVTEC's Avatar
how many miles are on the engine? have you ever used an induction cleaner? if not GM makes a good one, part # 1052626. we use that on all the hondas at work.
[Modified by whatVTEC, 4:04 AM 7/12/2002]
Old Jul 11, 2002 | 07:22 PM
StyleTEG's Avatar
Default Re: carbon buildup on inside of IM???? (whatVTEC)
Time to look for an oil catchcan.
That carbon buildup is a result of oil blowby reculated through the IM via the PCV system.
Old Jul 11, 2002 | 09:23 PM
servion's Avatar
Default Re: carbon buildup on inside of IM???? (StyleTEG)
Good idea... I've seen the endyn one.. but its pricy, and I've got an h-series motor. Any alternatives?
Old Jul 12, 2002 | 01:42 AM
kinesistech's Avatar
yeah, get over it. It doesnt hurt anything, if you dont like it, then clean it and dont run your PCV. Just keep in mind that almost EVERY engine has that, and its not the cause of your misfire.
RustyEOD
Honda CR-V & Element
Nov 3, 2011 05:42 PM
fg2si!kid
Welding / Fabrication
Dec 29, 2007 08:37 PM
95bkeg
Jun 3, 2006 12:27 PM
Blaze45
Jan 25, 2003 01:02 PM
