sohc vtec head on an 91 hf bottomend......able to be done?
Old Jul 11, 2002 | 09:31 AM
91sifreak's Avatar
New User
Default sohc vtec head on an 91 hf bottomend......able to be done?
My brother picked up a port and polished d16z6 head completely put together, 3 angle valve job, web cam, milled down .0030 i think he said (or something like that). Now we wanted to throw the head on a hf bottom end, the hf is a 1.5 and the head is a 1.6, can we do this? thanks for any help.
Old Jul 11, 2002 | 09:33 AM
89 CRX SI's Avatar
Default Re: sohc vtec head on an 91 hf bottomend......able to be done? (91sifreak)
yes you can but id think about doing a 1.6 block swap cause it would be better.
if you want to make a 1.5L monster then itll work great. HAVE fun
Old Jul 11, 2002 | 09:39 AM
4gvtec's Avatar
yes, you can.i have a allmost brand new z6 complete intake manifold for sale no injectors.if iterested! im about 45 min from you.
Old Jul 11, 2002 | 10:04 AM
Kimo's Avatar
Default Re: sohc vtec head on an 91 hf bottomend......able to be done? (4gvtec)
you can order a conversion head gasket from autozone- your probly gonna have to change the timing belt though-
Old Jul 11, 2002 | 11:39 AM
zcivic91's Avatar
Default Re: sohc vtec head on an 91 hf bottomend......able to be done? (Kimo)
yup just like d16a minime...
does the z6 head have the square or round cumbustion chamber? i think the y8 provides even higher compression..be so will the z6 head...probly bout 11.5:1 with the milled head.. also use the p28 ecu..it works wayyy better.
if the block can hanlde it and u got an si tranny...i can see you keeping up with b16's all day long...especially cuz u got the hf...
Old Jul 11, 2002 | 02:38 PM
technine's Avatar
What about the valve reliefs on the pistons? The HF only came with 8 valves, 2 valves per cylinder so the pistons have only 2 valve reliefs on them. The D16z6 head has 16valves. How would that work or does the valve reliefs not matter?
Old Jul 11, 2002 | 06:16 PM
zcivic91's Avatar
Default Re: sohc vtec head on an 91 hf bottomend......able to be done? (technine)
oh ****...yea thats right...ud have to either get an si block or new pistons
Old Jul 11, 2002 | 06:51 PM
rioninja's Avatar
I have never in my life seen an HF piston with only 2 valve releifs.
I dont think honda would design special pistons just for the one run of motors.
Old Jul 11, 2002 | 10:58 PM
Kimo's Avatar
Default Re: sohc vtec head on an 91 hf bottomend......able to be done? (RioNinja)
ive never even seen the hf block haha- but i know they have a gasket lol-
i did mimime on my crx- but then just put the whole z6 motor in , made my car loud as hell, my exaust was 2wice as loud.
Old Jul 12, 2002 | 03:09 AM
Mista Bone's Avatar
D Tranny Guru
16 valve head on 8 valve pistons.........
SMACK!
I can grap pics of HF pistons if needed.
Old Jul 12, 2002 | 11:26 AM
rioninja's Avatar
Default Re: sohc vtec head on an 91 hf bottomend......able to be done? (Mista Bone)
please do,
every hf i've seen in my life has had 4 valve releifs, and i've seen quite a few of them.
Old Jul 12, 2002 | 07:40 PM
Jockobo's Avatar
Default Re: sohc vtec head on an 91 hf bottomend......able to be done? (C5_ALLMOTOR)
i seen a car with a 16 valve head on his cx. its not that fast but it runs...
Old Jul 13, 2002 | 12:48 AM
Mista Bone's Avatar
D Tranny Guru
Default Proof in the pics............
[Modified by Mista Bone, 4:48 AM 7/13/2002]
[Modified by Mista Bone, 4:49 AM 7/13/2002]
Old Jul 13, 2002 | 04:27 AM
89 CRX SI's Avatar
Default Re: Proof in the pics............ (Mista Bone)
man mista you got everthing laying around
Old Jul 13, 2002 | 05:10 AM
USDM 4G VTEC's Avatar
judging from the pic i guess u gotta get urself a hold of a new block,,,, theres no point of getting pistons and stuff.... for that i rahter just get a A6 bock or even the Z6 block.... its better to go bigger displacement.... i dont wanna see that Z6 hittin that piston on VTEC. althought it will be funny see a valve flying tru the hood....
Old Jul 13, 2002 | 09:18 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Proof in the pics............ (89 CRX SI)
I just pulled those 2 motors apart this weekend.
95 CX thru a rod, so I put the CX crank with it's bearings into the HF block.
All it needs is pistons.
Z6 pistons on D15Z1 rods
Radim
Sep 1, 2008 09:15 PM
Sampsonite987
Mar 12, 2004 03:39 PM
RuthlessEF-9
Jun 8, 2003 10:20 AM
50shotRex
Apr 1, 2003 07:35 AM
