eacv valve
Old Apr 13, 2008 | 06:58 AM
juanchoenuncrx's Avatar
* B A N N E D *
Default eacv valve
what is the function of the eacv electronic air control valve?????????
what does it do
Old Apr 13, 2008 | 08:56 AM
~sp33~'s Avatar
EFB055
https://honda-tech.com/zerothread?id=2215013
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">The idle speed of the engine is controlled by the Electronic Air Control Valve (EACV). The valve changes the amount of air bypassing into the intake manifold in response to electric current sent from the ECU. When the EACV is activated, the valve opens to maintain the proper idle speed. After the engine starts, the EACV opens for a certain amount of time. The amount of air is increased to raise the idle speed anywhere from 150 to 500 rpm, dpending on which engine you have. When the coolant temperature is low (the ECU reads this from the Coolant Temp Sensor), the EACV is opened to obtain the proper idle speed. The amount of bypassed air is controlled in relation to the coolant temperature.</TD></TR></TABLE>
fenix4o9
Feb 25, 2010 11:03 PM
kev92ex4door
Jul 31, 2008 12:27 PM
dillonG_B
Feb 2, 2008 08:45 AM
ILOVEGIRLS
Dec 25, 2003 03:19 PM
