what is this sensor?
Old Dec 20, 2003 | 01:04 AM
ILOVEGIRLS's Avatar
Default what is this sensor?
what is the sensor that tells the ecu that the engine is warm and lowers the idle?
Old Dec 20, 2003 | 07:28 AM
Muckman's Avatar
Moderator in Chief
Default Re: what is this sensor? (ILOVEGIRLS)
the Idle Air Control Valve and the Fast Idler Valve work in conjunction to allow more air to bypass the throttle plate when the engine is cold resulting in a higher idle. They have coolant flowing through them that controls the valve based on the temperature of the coolant.
Modified by Muckman at 3:14 PM 12/20/2003
Old Dec 20, 2003 | 06:22 PM
ILOVEGIRLS's Avatar
Default Re: what is this sensor? (Muckman)
where is this located? can you tell me?
Old Dec 20, 2003 | 06:50 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
On the back of the Intake Manifold facing the firewall, I believe.
Old Dec 21, 2003 | 12:48 AM
Rad_Teg's Avatar
Default Re: what is this sensor? (Gee3)
iac valve on the back of the intake manny facing fire wall and the fast Idle underneath the throttle body.
Old Dec 25, 2003 | 03:19 PM
ILOVEGIRLS's Avatar
Default Re: what is this sensor? (Rad_Teg)
word..thanks, im gonna see if that is my problem.
jojo23
Honda CR-V & Element
Sep 21, 2017 05:29 PM
fenix4o9
Feb 25, 2010 11:03 PM
juanchoenuncrx
Apr 13, 2008 08:56 AM
VtecDA9
Jan 28, 2004 02:15 PM
