funny noise?
Old Apr 12, 2008 | 11:00 PM
panda_eh2's Avatar
Default funny noise?
i changed my wheels today and later on tonight my front passanger side front end started making a strange noise. t sounds like a ticking type of noise almost like the brakes are dragging but i can push the brakes and the noise is still there. the noise doesnt go off of the rpms only off of the speed. it makes it when the clutch is in or out, in gear or neutral. also one time right before it started making the noise i went to backout of a parking spot and it felt like something was dragging really bad. any suggestions would be great. 94 hatch w/gsr
Old Apr 12, 2008 | 11:14 PM
obuhmyuh's Avatar
Default Re: funny noise? (panda_eh2)
lug nuts on tight enough? sounds like a pad dragging on the rotor or a loose rotor... how does your axle/axle nut look?
Old Apr 12, 2008 | 11:19 PM
panda_eh2's Avatar
when i push the brakes it dosent stop. i took the lugs back off and made sure they were tight and that didnt fix it
Old Apr 12, 2008 | 11:29 PM
obuhmyuh's Avatar
Default Re: (panda_eh2)
sounds like something is loose to me, have you done any repairs or work to your brakes or tires? is it the front tires, one tire, all tires???
obuhmyuh's Avatar
Default Re: (obuhmyuh)
or actually your rotors might be warped.
Old Apr 12, 2008 | 11:53 PM
panda_eh2's Avatar
i dont think it is the rotors because when i push the brakes it still makes the noise
Old Apr 13, 2008 | 09:11 AM
obuhmyuh's Avatar
does your car shake?
Old Apr 13, 2008 | 09:22 AM
Blzdeep's Avatar
di you check to make sure the backing plate is clear ?
Old Apr 13, 2008 | 12:13 PM
panda_eh2's Avatar
no the car dosent shake. if you are talking about the dust shield i took it off ecause i thought that might be making the noise but that didnt help
Old Apr 13, 2008 | 12:17 PM
Blzdeep's Avatar
so no shake ... i'll rule out the strut then ... maybe axel is not seated properly ? just throwing it out there. i know the feeling
Old Apr 13, 2008 | 01:14 PM
panda_eh2's Avatar
i might try to take the brakes off tomorrow morning. maybe one of the pads is broken?
Old Apr 13, 2008 | 02:07 PM
obuhmyuh's Avatar
or worn down really bad and you cant see it... what about tire balancing?
me_brewsta
Oct 27, 2016 05:55 PM
Myaax7
Honda Civic (2006 - 2015)
Sep 14, 2009 05:24 PM
Landshark68
Jul 15, 2006 09:12 AM
accord_si
Jun 21, 2006 02:08 PM
dj626
Jul 10, 2005 05:31 PM
