wastegate wont let me rev out?
i just bought a turbo kit from my friend for my d15 and brought it to a shop to have it put on, i just got it back today its not tuned or anything but when im on the gas i can only rev out till 4grand untill my wastegate kicks in and i cant rev no more anyone know what the problem could be?
Your wastegate opening has no effect on you being able to "rev it out" or not. You might want to re-diagnose your issue.
Maybe he put an early rev limiter in because he knew you'd take your freshly turboed and *untuned* car out and beat the **** out of it.
LOL...well lets see...your driving an UNTUNED turbo car......
i wonder why it breaks up around 4k (probably about the time the turbo spools).
Man,not trying to be a dick,or mean,but maybe you should research ALOT about a turbo/concept of a turbo car before you actually drive a turboed car,or you might be replacing the motor quite a bit.
You cant slap on a turbokit,not tune it,and expect it to run and function properly.
i wonder why it breaks up around 4k (probably about the time the turbo spools).Man,not trying to be a dick,or mean,but maybe you should research ALOT about a turbo/concept of a turbo car before you actually drive a turboed car,or you might be replacing the motor quite a bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Car Tweaker »</TD></TR><TR><TD CLASS="quote">its not a rev limiter bcuz when im in neutral i can rev out to where im suspose too but one im in gear and i get a lil past 4 it breaks up</TD></TR></TABLE>
well if the shop that installed it has even the slightest knowledge about hondas, they set your car up with a boost cut at something like 3 psi so if you hit boost you dont blow your motor up because the car is untuned.
stock map is fine to just shy of 12 psi, may be cutting out due to going lean? or blowing out spark
Modified by Garage 808 Hatch at 6:28 PM 4/13/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch »</TD></TR><TR><TD CLASS="quote">stock map is fine to just shy of 12 psi</TD></TR></TABLE>
Not if it isn't rescaled, which is definitely possible in this "untuned" car.
