b20 swap help!
help!!!! i need to get the swap done today.. will it work if im using a 99-00 SI rear mount with a rear b series bracket?
or do i need the d16 mount with the b series bracket?
no dude! he just told you the info you need to know but i guess you're stuborn to listen. if you're using the 2000 si mount in the rear than you'll also need the 2000 si bracket (em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trimugenhatch »</TD></TR><TR><TD CLASS="quote">no dude! he just told you the info you need to know but i guess you're stuborn to listen. if you're using the 2000 si mount in the rear than you'll also need the 2000 si bracket (em1) </TD></TR></TABLE>
that surely is NOT what the other dude said. he told him he needed a b series rear bracket.
and yes, ^ is correct. youll need the 99-00 si t-bracket. obviously if this is going in a 96-00 civic
kholmes
Jul 10, 2003 05:15 PM
