JDM ITR HUB BEARING
i knew it will but dayum les schwab didnt wanna touch my car cuz its motified 4-5 lugs! ahhaha i'll have honda or someone do it! my **** is bad!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 »</TD></TR><TR><TD CLASS="quote">not if its a jdm itr 5 lug swap (36mm axles) I have read that crv bearings will work.</TD></TR></TABLE>
yeah i have the 36mm one! so the gsr and usdm itr wont work?
Ignore the guys that are saying it will work. They are making uneducated guesses. I don't get why so many people assume.
The guys saying that the JDM and USDM ITRs are different are correct and yes, they're right about the USDM 32mm and JDM 36mm axles.
The JDM ITR bearing has an outer diameter of 84mm and inner of 45mm.
The USDM ITR has the same knuckle as the regular Integra which takes a bearing with a 79mm outer diameter.
I believe the JDM ITR front knuckle setup is the same as the 97-01 CR-V. Your best bet is to try a CR-V/RSX bearing (also 84mm OD, 45mm ID) as someone mentioned earlier.
Also, an RSX-S hub (or 2nd gen CR-V) is a cheaper alternative to the JDM ITR or 97-01 CRV hub. The only thing is you'll need a small hub centric thing so your rotor doesn't shift. The RSX-S hub is the same as the 97-01 CRV hub except that it has a bit of material shaved off sides the hub face and the part that sticks out of it to support the rotor.
Modified by Player_One at 1:30 PM 4/13/2008
94allmotor
Mar 16, 2011 12:47 PM
FRKWOO
Jan 15, 2011 06:47 PM
boostedcivicsir
Jul 2, 2003 01:44 PM
