Suspension & Brakes Theory, alignment, spring rates....
?????REAR Struts with Kens Customs Spindle mount ??????
Old Apr 12, 2008 | 07:06 PM
Sir2egk's Avatar
Default ?????REAR Struts with Kens Customs Spindle mount ??????
i need help on rear spindle mount that i bought off of a member of this forum
i want to know what kind of rear struts this suspension uses . i though it used stock struts but once i started putting it together its not it
i want to know what kind and where can i get it from
car is not done yet, i put it like that so it can roll in and out my garage and i still have to cut off that rear shiet
Old Apr 12, 2008 | 07:15 PM
98vsmhatch's Avatar
What Exactly are you asking???
Looks to me you have OMNI Coilovers(for EG)
They are not stock..... But they are the right Suspension for the rear of your car.
I'm not 100% sure thats what your looking for.
Old Apr 12, 2008 | 07:28 PM
Sir2egk's Avatar
Default Re: (98vsmhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vsmhatch &raquo;</TD></TR><TR><TD CLASS="quote">What Exactly are you asking???
I'm not 100% sure thats what your looking for.</TD></TR></TABLE>
well my friend told me that it might use something like this but not sure
just the bottom half, but then how about the top
Old Apr 12, 2008 | 07:36 PM
98vsmhatch's Avatar
Ok, well i can tell you that the suspension that is in those pictures is the OMNI setup for a 92-95 honda civic. I can also tell you that it will probably not be capable of giving the performance you need out of the suspension with what your looking to do with the car.
I will however let someone else chime in and respond to your post who has more knowledge of actual drag racing suspension kits and setups to further help you with this process!
Old Apr 12, 2008 | 08:11 PM
blinx9900's Avatar
Default Re: ?????REAR Struts with Kens Customs Spindle mount ?????? (Sir2egk)
is it just me or does it look like ek/ej shocks will fit on there? try using some thick washers like people do when they put eg shocks on ek/ej?
Old Apr 12, 2008 | 08:22 PM
Sir2egk's Avatar
Default Re: ?????REAR Struts with Kens Customs Spindle mount ?????? (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">is it just me or does it look like ek/ej shocks will fit on there? try using some thick washers like people do when they put eg shocks on ek/ej?</TD></TR></TABLE>
it doesnt sit on it right, and washers wont help either
just in case someone ask, whats the car used for and setup
fully built N/A kseries 305whp
same motor in my 2400lb teg ran 11.4@120 now with this car ?????
Old Apr 13, 2008 | 11:15 AM
vietjdmboi's Avatar
already retired the itr?? i swear i just saw it like a month ago or so.
Old Apr 13, 2008 | 06:06 PM
Sir2egk's Avatar
Default Re: (vietjdmboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietjdmboi &raquo;</TD></TR><TR><TD CLASS="quote">already retired the itr?? i swear i just saw it like a month ago or so.</TD></TR></TABLE>
i needed something lighter, that pig kept on getting beaten by waaay lighter cars so i needed to get something lighter be in the same limit
Old Apr 13, 2008 | 07:23 PM
vietjdmboi's Avatar
Default Re: (Sir2egk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sir2egk &raquo;</TD></TR><TR><TD CLASS="quote">
i needed something lighter, that pig kept on getting beaten by waaay lighter cars so i needed to get something lighter be in the same limit </TD></TR></TABLE>
should have kept that gold eg. now that was a beast.
Old Apr 15, 2008 | 10:35 PM
Sir2egk's Avatar
anybody ????????????
Old Apr 19, 2008 | 04:53 PM
matz03's Avatar
Try posting this in the drag race forum, those guys should know which straight axle kit this is and what it might need to complete it.
Old Apr 19, 2008 | 09:09 PM
slammed_93_hatch's Avatar
correct blinx, he just needs two 5mm spacers on each side and he will be good to go.
MatBorgia
Suspension & Brakes
Jul 17, 2017 06:59 PM
crxpwr1
12
Jul 23, 2006 06:27 PM
The Show Stopper
Dec 19, 2005 06:55 AM
