At it again another project under my belt -part 1 turbo set up
Old Apr 12, 2008 | 02:24 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default At it again another project under my belt -part 1 turbo set up
After going through so many set ups I've done another one. Im just showing my manifold and turbo set up that was just finished today By Randy http://www.eville140.com
looking for 450ish on pump t3/t67 or whatever i can get. if more than im ever happier...lol
b18c benson sleeves
hondata s300
still confused on fuel set up
Enjoy
Modified by HybridcivicLS-T at 6:32 PM 4/12/2008
Modified by HybridcivicLS-T at 6:36 PM 4/12/2008
Old Apr 12, 2008 | 02:39 PM
00hatch's Avatar
one bad *** DP
Old Apr 12, 2008 | 02:47 PM
TayTeg91's Avatar
Default Re: (00hatch)
looks good, nice pie cuts
Old Apr 12, 2008 | 03:28 PM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00hatch &raquo;</TD></TR><TR><TD CLASS="quote">one bad *** DP</TD></TR></TABLE>
x2
Old Apr 12, 2008 | 03:41 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (95jeremie)
u wouldn't even guess how much i paid! No one on this site can even touch it. no one that i know unless i made it and i don't know how. All high quality parts, he has almost every jig he made it exactly of what i wanted for less than a SS inlinepro manifold Manifold and DP flanges dump tube flex, everything for less than a brand new inline pro...lol
he makes them for fun and doesn't charge tons of labor.
Old Apr 12, 2008 | 04:12 PM
Schister66's Avatar
Man U FTW
Looks awesome. I love the Whitey bend dp
Old Apr 12, 2008 | 06:37 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (Schister66)
i love everything about it....lol
Old Apr 13, 2008 | 06:19 AM
thermal's Avatar
keep an eye on that O2 bung downstream of the flex pipe... it looks like it might be directly undeneath the axle/midshaft.... meaning, the O2 sensor might get in contact with a rotating component..... other than that, great job!
Old Apr 13, 2008 | 06:31 AM
Evile140's Avatar
Default Re: (thermal)
Would it be better if it pointed at a 45 degree angle either direction? I'm the one that put the above stuff together, just don't have a trans here. I was going off the o2 placement from a downpipe that came in a greedy(I know I spelled it wrong ) kit.
I will stop by the salvage yard on the way home tomorrow and check out the ls's they have.
Thanks
Randy
Old Apr 13, 2008 | 06:55 AM
thermal's Avatar
Well, it may work just fine.... but remember that a 3 inch DP is taller... yup, I've done a 45 degree placement before and worked.... You should just mount the midshaft even without the tranny just to get a better reference.... just a thought....
Old Apr 13, 2008 | 07:15 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (Evile140)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evile140 &raquo;</TD></TR><TR><TD CLASS="quote">Would it be better if it pointed at a 45 degree angle either direction? I'm the one that put the above stuff together, just don't have a trans here. I was going off the o2 placement from a downpipe that came in a greedy(I know I spelled it wrong ) kit.
Thanks
Randy
i was goinig to send you a link...lol You can do whatever you think would be right. If you want to change it to a 45 degree angle then that's fine as well.
ahobbs
Appearance Build Threads
Jun 30, 2008 06:35 PM
jdmkid8383
Mar 20, 2008 12:11 PM
Turbo-charged
Welding / Fabrication
80
Mar 15, 2008 10:51 AM
eglslsd
Jun 1, 2007 07:33 PM
Hondata
Apr 3, 2002 06:18 AM
