rubber oil return line okay heatwise?
Old Apr 12, 2008 | 12:29 PM
cruiseMain's Avatar
Default rubber oil return line okay heatwise?
i have two pushlock/socketless -10 AN fittings and a -10 AN pushlock hose that is rated to 212 degrees. would that be okay to run? im afraid it will melt.... i do have some reflective heat wrap but i was wondering how hot the oil itself would get. would it actually work to prevent any heatsoak to the hose? thanks in advance!
Modified by cruiseMain at 1:35 PM 4/12/2008
Old Apr 12, 2008 | 01:04 PM
jewjew bean's Avatar
Default Re: rubber oil return line okay heatwise? (cruiseMain)
I was under the impression that push lock hose would be fine but if it's only rated for 200 I wouldn't use it. Perhaps you could find some high temp stuff
Old Apr 12, 2008 | 01:15 PM
cruiseMain's Avatar
Default Re: rubber oil return line okay heatwise? (jewjew bean)
but something that would seal over a pushlock fitting? you dont think the heat wrap will help?
Old Apr 12, 2008 | 04:25 PM
cruiseMain's Avatar
bump plz let me know if its okay to use that hose with heatwrap over it??
Old Apr 12, 2008 | 05:15 PM
if it's only rated for 200F, don't use it..... your oil is going to get a lot hotter than that
Old Apr 12, 2008 | 05:43 PM
97grnrs's Avatar
ive used rubber hose for oil drain b4. u just have to change it every few months. it gets soft after a while.
GSROWNSU's Avatar
push loc hose should have a better heat rating then that...my push-loc hose is rated to like 300 psi and close to 350 degrees Fahrenheit. I got it from atp turbo
Old Apr 12, 2008 | 07:58 PM
Runnerdown's Avatar
Default Re: rubber oil return line okay heatwise? (97grnrs)
Really depends on how close it is to anything. Heat wrap is a good idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">ive used rubber hose for oil drain b4. u just have to change it every few months. it gets soft after a while. </TD></TR></TABLE>
Thats what happens when you use heater hose usually. Or any type of rubber hose that is not meant to contact oil. Petroleum will deteriorate common rubber hoses...it has to be pushlock hose, AN or something made from compatible material.
Old Apr 12, 2008 | 08:36 PM
blackeg's Avatar
im using some right now, regular old heater hose from autozone. it does get soft i change it every few months. no problems with it so far
oh, my return line is about 5 inches away from my dumptube itself, and aroound 8 inches from my downpipe
Dave_Dc2
Jun 19, 2010 03:56 PM
K i l l a B e e.
Sep 30, 2007 03:41 PM
lsvtec101
Jan 19, 2003 12:17 PM
C1V1CS1
Oct 16, 2002 12:23 PM
Jockobo
Jun 15, 2002 07:41 PM
