Do they make a torque damper for EF???
Old Apr 12, 2008 | 10:56 AM
MyLilCivic's Avatar
Default Do they make a torque damper for EF???
Been looking for some time now for a torque damper for my B series Ef but i cant find any kind or torque damper for it.
Is there anything out there that can help the motor from rocking i have Hasport mounts all ready????
Old Apr 12, 2008 | 11:56 AM
grog's Avatar
Default Re: Do they make a torque damper for EF??? (MyLilCivic)
Hasport inserts come either soft and hard IIRC
this is from hasport website " This mount kit is available with different polyurethane inserts.
The most common and softest is the street, followed by the race for track cars, and extreme race. "
and they also have solid mounts now
I just ordered a oem front tranny mount, I plan on mocking it up an welding in a new mounting point for it on the crossmember. I was planning on taking some pics and doing a write up on how to add the front mount.
btw if that mount isnt stiff enough I was considering using the window weld to stiffen it up.
btw could one of your mounts be broken or cracked?
Modified by grog at 1:01 PM 4/12/2008
Old Apr 12, 2008 | 12:14 PM
superhatchbackbros's Avatar
BUMP i would like to know about this also, damper for engine bay??? i have hassport d sereis oem kit and still kinda rocks but not as bad, but i wanna stiffin it up alot more.
Old Apr 12, 2008 | 12:44 PM
grog's Avatar
If you have the tools to fab up some sort of barcket you should be able to make one of these work http://www.lightningmotorsport...y.htm
They dont seem like they would be as effective as some stiff mounts.
Do a search and you will find some stuff on this.
B18C5-EH2
Aug 22, 2008 03:57 PM
blazed_racer
18
Jun 25, 2008 05:29 PM
strawberry
Mar 14, 2008 04:34 PM
Ak_ef9
Feb 23, 2007 02:27 PM
Unknown Member
May 4, 2003 01:49 PM
