Excited - Chipping (well rechipping) my first ECU
Old Apr 12, 2008 | 09:34 AM
TheMuffinMan's Avatar
He knows where you live!
Default Excited - Chipping (well rechipping) my first ECU
Hey everyone,
I recently acquired a chipped P28 in a trade for my stock P13 and have already ordered the necessary parts to socket it (depressingly it was soldered straight in). I'm a fairly good at soldering/desoldering as I build boards and what not for a professor of mine at college.
So with that being said I have a few questions:
1) I build a USB programmer at work that's used to flash PIC microprocessor chips, the software we use is PiCKIt 2. Does anyone have any experience with this stuff? PickIt only burns HEX documents to the PIC controller so I know I can't use that software but the burner should work for the Atmel chip on the ECU correct? (I'm not at school and don't have it desoldered yet so I can't try)
If it does work those programmers only cost $35 vs the like 80+ I've seen on other sites so if someone needs one I can hook them up
2) In regards to the two .1uF capacitors I've seen listed (ref: http://www.superhonda.com/tech....html) Are they really necessary? I bought them and will probably be putting them in, I was told they were strictly noise reduction to clean up the signals.
3) In regards to Crome/Uberdata I downloaded both packages and some maps and took a look, and Crome seems immediately more user friendly. Is that because it's dumbed down and has less features ? Or just that it is a bit more intuitive? Uberdata confused me with it's Ostrich/Reg release deal where for datalogging you have to like open a base in Ostrich, then the one you want to flash, then close it , then open it in the regular to size it properly? Does anyone else have any input? I will probably be running around on a H22A I/H/E P28 tune done by Matt Shue of Richmond I found for download on pgmfi's site. Will this be detrimental to my car in any way? I understand that base maps aren't meant for you to stay on forever but as a temporary solution until I can get it fully tuned will it work fine?
Old Apr 12, 2008 | 09:53 PM
mtber's Avatar
Default Re: Excited - Chipping (well rechipping) my first ECU (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">
3) In regards to Crome/Uberdata I downloaded both packages and some maps and took a look, and Crome seems immediately more user friendly. Is that because it's dumbed down and has less features ? Or just that it is a bit more intuitive? Uberdata confused me with it's Ostrich/Reg release deal where for datalogging you have to like open a base in Ostrich, then the one you want to flash, then close it , then open it in the regular to size it properly? Does anyone else have any input? I will probably be running around on a H22A I/H/E P28 tune done by Matt Shue of Richmond I found for download on pgmfi's site. Will this be detrimental to my car in any way? I understand that base maps aren't meant for you to stay on forever but as a temporary solution until I can get it fully tuned will it work fine?</TD></TR></TABLE>
1. You don't need them. We have never seen negative results without them.
2. Considering it sounds like you have a basic setup, crome should be fine.
Crome is much more user friendly then uberdata & in my opinion has a better platform. I would personally recommend you look into Neptune, eCtune, Hondata if you are seriously thinking of DIY tuning. You will thank your self later on down the road
Running on a basemap can be a bad idea if you don't know where the basemap really came from etc. On an n/a setup that is basic like yours, you really won't take a huge risk of engine damage.
Old Apr 13, 2008 | 01:06 PM
I appreciate the help mtber.
I am planning on playing around with the tuning to see what I can find, hadn't even heard of eCtune and Neptune I've seen a bit here and there about.
Thanks
Old Apr 13, 2008 | 01:27 PM
zccr-xsi's Avatar
ectune isnt free ull have to pay for that as well as crome pro.u should try out crome frist just to get started heres the site.www.tuningwithcrome.com download 1.4
Old Apr 13, 2008 | 05:45 PM
Thanks for the help zccr I actually found the site before you posted haha and downloaded the latest crome and the latest uberdata (from pgmfi)
I'm going to play with it, I think the only "tuner" in my area uses Uberdata
Old Apr 14, 2008 | 04:14 AM
zccr-xsi's Avatar
ive heard good thing about uberdata but ive never used it before,i always stuck with crome pro.
Old Apr 16, 2008 | 02:44 PM
Got everything soldered up and it's working great!
I'm now socketed (ZIF with the raised up socket) and added the two capacitors.
Now I have a question, where are you guys buying the Atmel chips? Only place I can find is JDR and they want $25 + shipping!
Old Apr 16, 2008 | 03:11 PM
98vtec's Avatar
moderator emeritus
Default Re: (TheMuffinMan)
use an sst chip from http://www.moates.net
Old Apr 16, 2008 | 04:06 PM
Thanks for the link 98vtec!
Old Apr 17, 2008 | 01:35 AM
zccr-xsi's Avatar
moates i where i get ALL MY STUFF only thing that sucks is he doesnt sell sst chips by the bundle but look here for 25 bucks ull get 5 sst chips.
http://www.xenocron.com/catalo....html
95sloweg
19
Apr 22, 2009 11:43 AM
sikcrx80
May 29, 2006 09:29 AM
snowblind7x
Nov 3, 2005 05:25 PM
ek2k
Apr 16, 2005 06:13 PM
goose21
Apr 19, 2004 08:32 AM
