Suspension & Brakes Theory, alignment, spring rates....
Does ASR Subframe brace work with Function7 rear control arms?
Old Apr 12, 2008 | 08:37 AM
s10matt's Avatar
Default Does ASR Subframe brace work with Function7 rear control arms?
Just as the title says...
94 2dr integra btw...
I wanted to make sure before I bought the part, Ive looked in some searches and couldn't find exactly what I was looking for. Id feel a little more comfortable seeing some responses from the forum.
Any help is greatly appriciated, Thanks guys
Old Apr 12, 2008 | 07:03 PM
98vsmhatch's Avatar
If the ASR brace works w/ stock LCA's why wouldn't they work with F7 LCA's?
They work together fine, look up the Threads in appearance/cosmetic section to see all the setups being used.
Old Apr 14, 2008 | 08:58 AM
Function7's Avatar
Default Re: Does ASR Subframe brace work with Function7 rear control arms? (s10matt)
Yes, the ASR subframe will fit with no problems. The ASR sway bar linkage is is also compatible with our arms.
We designed our arms based on the stock arms and so they are compatible with a lot of other add-ons out there
-A
Old Apr 16, 2008 | 02:59 AM
Elwuudz's Avatar
Default Re: Does ASR Subframe brace work with Function7 rear control arms? (Function7)
My setup is 93 Del Sol
Skunk2 Pro F Camber
Omni R Camber
Tein Flex
F7 RLCA's
205/50/15
An ASR brace and Bars; I have waited to install until I have all nessesarry information. F/R suspension techniques bars a on Del Sol equipped without oem F/R bars seems a difficult task.
Last time I had it on a lift I adjusted the camber and rotated the tires. I noticed the suspension techiques bars endlinks supplied don't seem to interface with the F7 RLCA's. Do I need to buy endlinks from kingmotors? or could I get the brackets they supplied to fit?
What endlinks are required? Post a link PLZ
Old Apr 17, 2008 | 09:44 PM
Function7's Avatar
Default Re: Does ASR Subframe brace work with Function7 rear control arms? (Elwuudz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elwuudz &raquo;</TD></TR><TR><TD CLASS="quote">My setup is 93 Del Sol
Skunk2 Pro F Camber
Omni R Camber
Tein Flex
F7 RLCA's
205/50/15
Which ST sway bars do you have? There are two types: -
One for cars that did not come with sway bars. This type of ST bars connect to the lower end of the rear shock - no linkages needed, just the ST hardware.
The 2nd type is a stock replacement sway bar. These utilize the stock linkages. You should be able to use your stock linkages or our linkages (if you want the adjustable feature).
Post a pic of what you've got and we'll point you in the right direction.
-A
Old Apr 18, 2008 | 05:31 AM
Elwuudz's Avatar
WICKED! a person with a f7 avatan...
I have the del sol S; so no OEM sway bars at all
The ST kit came with an incredible amount of hardware and very vauge instuctions.
I guess I could post up pics if needed, All i need is a pic of the front and rear installed on an eg and I should be set.
A few pics will do te trick for me.
Old Apr 25, 2008 | 03:48 AM
Elwuudz's Avatar
expletive!
Old May 5, 2010 | 04:53 PM
Function7's Avatar
Originally Posted by Elwuudz
expletive!
Did you get it installed yet?
-A
Old Aug 3, 2010 | 07:27 PM
team top secret's Avatar
[IMG][/IMG]
my set up with the F7 they look sick
Old Aug 4, 2010 | 10:35 PM
98civdx's Avatar
Master Detailer
^^ looks good, i cant wait to get the full function7 setup
My friend has it and it looks so good.
davidluko
Suspension & Brakes
Mar 30, 2009 05:47 PM
patrick4588
Suspension & Brakes
Jan 12, 2009 09:40 AM
pancake56
Jun 27, 2004 07:35 PM
cnk600
Dec 3, 2002 11:53 AM
