Caster
Checked my alignment last night, im at -2.7 up front in caster
im way off from spec. If you stand and look at the car form a side point of view, you can see the tire sort of pushed back closer to the door. (not sure if you're understanding that) Here's the thing, couple months ago i hit a curb head on at about 40-50mph. Any idea what is causing my caster to be off wack like that? Thanks
00 civic ex
eibach sportline lowering springs
Tokico blue shocks
Si rims
Modified by ware at 9:33 PM 4/12/2008
im way off from spec. If you stand and look at the car form a side point of view, you can see the tire sort of pushed back closer to the door. (not sure if you're understanding that) Here's the thing, couple months ago i hit a curb head on at about 40-50mph. Any idea what is causing my caster to be off wack like that? Thanks00 civic ex
Tokico blue shocks
Si rims
oh never mind, I see you are part of the EJ8 squad.
I think at that speed, that is enough impact to bend the control arms, upper or lower. My guess would be the uppers.
Modified by PIC Performance at 10:38 AM 4/12/2008
I had the same thing happen but only on the right side, and not as badly as yours. I replaced a bent lower control arm, shock fork, and tie rod end, and it helped. I still have the caster issue and it makes the steering a little twitchy. Now I am convinced that my upper control arm is bent too and possibly my front spindle.
For your car you might have to replace most every suspension part from the crossmember forward??? yours is worse than mine so at the very least everything i need and more??? what do i know. best of luck
here is a pic of my bent control arm, you can use the seam as a guide.
Modified by gringo7718 at 3:11 AM 4/15/2008
jadugartir
Jan 6, 2008 12:16 PM
killerbee310
Suspension & Brakes
Jan 8, 2006 10:11 PM
