cam shaft on old cam gears question!? please help!
Old Apr 11, 2008 | 11:56 PM
integra gsr96's Avatar
Default cam shaft on old cam gears question!? please help!
i was wondering if there would be any problems with stock cam gears on a new skunk 2 pro 2 cam shaft? for a integra gsr 96. please help.!
Old Apr 12, 2008 | 12:45 AM
civicstar's Avatar
Default Re: cam shaft on old cam gears question!? please help! (integra gsr96)
if you don't want to adjust cam degree then it wouldnt matter
Old Apr 12, 2008 | 07:39 AM
Default Re: cam shaft on old cam gears question!? please help! (civicstar)
is it cool if i push about 200+ with stock cam gears?
Old Apr 12, 2008 | 07:40 AM
and does it even help? adjustable cam gears?
Old Apr 12, 2008 | 09:21 AM
civicstar's Avatar
it helps when you need to adjust the overlap on the cams with the gears, when you have high compression pistons and high lift cams you don't really want to adjust the timing because you might have valve to piston contact.
you can push 200+ depending on the cam combination with your motor, you can gain up to 2 hp a wide range of hp from just adjusting your cam degree if you need too, with stock camsshafts you don't really notice a difference by adjusting them but aftermarket you tend to see a few hp gains because of correctly adjusting overlap
Old Apr 13, 2008 | 05:12 PM
ohk thanks alot!
EGunit
Aug 5, 2007 11:23 PM
Reis
Jul 20, 2005 02:44 PM
[DOD]Ak_RaPi$T~
Nov 17, 2001 01:42 PM
BlueG3Teg
Sep 4, 2001 06:14 AM
