b20Z2 questions
I am not standing in front of my car but I believe that is red lines at 6800 like the Teg LS's as for when the limiter kicks in I am not sure. My LS kicks in at 7200. The next time I drive my CRv I will find out. I hope that helps.
here you go. save this link to your favorites. everything you need to know about that motor is in here. i just rebuilt and installed my b20z2. its the best nonvtec motor i've ever driven. hope this helps. dont forget that the rod bolts are one, if not the biggest point of failier in your motor. change them out for arp's and im sure you can rev a little higher. good luck.
http://powweb.hondahookup.com/...v.pdf
jdmsiblue1
May 25, 2006 03:51 PM
