Spongy brakes
Old Apr 11, 2008 | 08:22 PM
stillsmokey's Avatar
Default Spongy brakes
My 90 Civic has been stored for 5 years, took it out for a tear and the brakes are spongy as hell. I've flushed/bled the brake system, and replaced the rear wheel cylinders... My question is what should i try next, Master cylinder, calipers?
Old Apr 11, 2008 | 08:54 PM
Mugen112's Avatar
I would try the master cylinder next.
Old Apr 14, 2008 | 04:07 PM
Default Re: (Mugen112)
I went to the parts place and they don't sell a rebuild kit, does anyone know if/where i can get one online?
Old Apr 14, 2008 | 08:24 PM
tico's Avatar
yea. look at the home page on HT. its a company called Statracing. replacement OEM parts. not bad prices either
Old Apr 14, 2008 | 08:59 PM
Default Re: (tico)
Checked, they don't have rebuild kits, just new/reman units.
Old Apr 14, 2008 | 09:03 PM
CP9A6M's Avatar
Default Re: (stillsmokey)
I'm not totally sure, but I don't think they make rebuild kits for aluminum master cylinders. I think just for the old school steel ones...
Old Apr 14, 2008 | 09:28 PM
StylishDOHC's Avatar
Default Re: (CP9A6M)
Can you really not afford $40 for a reman master?...rebuilding an old one hardly seems worth it, and the body is probably far too corroded anyway
Old Apr 14, 2008 | 09:52 PM
CP9A6M's Avatar
Default Re: (StylishDOHC)
And even if you could rebuild it, what if the whole problem was a scored cylinder bore? Just get the reman master cylinder. Can't really be much else unless you have some sort of leak in the system.
Old Apr 15, 2008 | 12:10 AM
liv4powder's Avatar
definitely check for leaks if you haven't already.
Old Apr 15, 2008 | 12:12 AM
ZCcivicBOI's Avatar
check the big vaccume line that goes from the brake booster to the intake manifold i had thise problem before and it was because that hose was clogged and thet gray valve in the hose was bad.
Old Apr 15, 2008 | 05:39 AM
I just wanted to pick up rebuild kits for the Master cylinders and calipers, as the calipers are 68 each and the master cylinder was $80, i figured i'd just rebuild it all and eliminate those as possible problems, but it doesn't look like i'll get off that easy.
OH, as for the vac line going to the booster, i've got it tee'd off to go to my Vac manifold as well, could that hurt anything?
Old Apr 15, 2008 | 09:19 PM
Turned out to be a pinhole in one of the lines going along the firewall from the prop valve to the M/C...Good thing i went and got a DA booster/MC today at the pick n pulll
thecruzs2007@yahoo.com
Mar 20, 2010 03:52 PM
Allurian
Suspension & Brakes
10
Oct 2, 2008 07:41 PM
suprmods
Oct 16, 2006 03:06 PM
miataguy
Jul 8, 2003 09:00 PM
delSolLS
Jul 4, 2002 06:33 PM
