Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
question on toe
Old Apr 11, 2008 | 05:59 PM
90_EX_Civic's Avatar
Default question on toe
what toe are you guys running for auto x? was just wondering if a total of 2 degrees out is to much for the front??? and it's for a stock height civic.
Old Apr 11, 2008 | 06:43 PM
climb_on's Avatar
Default Re: question on toe (90_EX_Civic)
not to sure about that 2* out
is the car stock?? what kind of tires?
settings like that your tires will be gone before you ever make it to your first event!
i run 0* toe up front and factory out back
sts integra, rt-615's
Old Apr 11, 2008 | 07:04 PM
Default Re: question on toe (climb_on)
damn, but it's not a dd so it's only going to be driven to-at-home, and that's it. and im running the same rt-615's in 14. running HS . if it really is that bad i'll just try it out this weekend and switch it back to stock after. and yeah, i know all that toe well probably destroy my tires, but i don't go to far out of my region. max is what, 45min drive. so well see how it goes. thanks with the info. anyone else.
Old Apr 12, 2008 | 04:43 AM
1999all_motoR_teg's Avatar
I run 1/16 total toe up front and 0 toe in the rear.
Old Apr 12, 2008 | 09:56 AM
SleeperGSR's Avatar
Default Re: question on toe (1999all_motoR_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999all_motoR_teg &raquo;</TD></TR><TR><TD CLASS="quote">I run 1/16 total toe up front and 0 toe in the rear.</TD></TR></TABLE>
X2 any more up front will destroy tires and make the car twitchy
Old Apr 12, 2008 | 04:35 PM
The Destroyer's Avatar
Default Re: question on toe (SleeperGSR)
Just a general question, when lowering a car do the rear tend to toe in?
I got an alignment a couple months ago, but am now questioning the job.
Old Apr 13, 2008 | 08:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">
X2 any more up front will destroy tires and make the car twitchy</TD></TR></TABLE>
yeah, well you don't drive this. and it actually worked out pretty well. rotated just fine. better then i thought.
[IMG][/IMG]
azian21485
10
Jul 13, 2004 06:46 AM
MHill
11
May 27, 2004 05:29 AM
ceboyd
17
May 19, 2004 02:35 PM
CrX-To-Tha-Max
Apr 8, 2004 10:19 PM
BABY NSX
Apr 22, 2003 12:13 PM
