Washers from drain bolts! Reuse or new ones?
Old Jul 11, 2002 | 07:13 AM
Fuster_Cluck's Avatar
Default Washers from drain bolts! Reuse or new ones?
Does it matter if you reuse the same washers for the drain bolts?
Examples: oil plug drain washer / transmission washer at drain plug.
I am about to drain my transmission and do NOT have an extra washer. I heard you can reheat the washer and use it again. ...or can you just reuse the old washer w/o reheating?
Old Jul 11, 2002 | 07:17 AM
johnzm's Avatar
Default Re: Washers from drain bolts! Reuse or new ones? (LX98Civic)
teya re supposed to be ditched, not reused. but unless u start to see leaking, i woudlnt worry about it.
Old Jul 11, 2002 | 07:20 AM
dpo95si's Avatar
you can reuse it on your tranns b/c how often do you change tranns oil? on the motor oil you could get away with it a couple of times and then i'd go to honda an pay the .50 cents and get another. when i bought my del sol the ring had never been changed and was as flat as foil and the plug leaked and i was like wtf!
Old Jul 11, 2002 | 07:22 AM
USDM 4G VTEC's Avatar
use the old one
i always use the old one and never got problems... keep an eye, and if it leaks then change it. but i wouldnt worry about it. they have never leaked on me...
Old Jul 11, 2002 | 08:59 AM
Urban Business
Guest
Posts: n/a
Default Re: Washers from drain bolts! Reuse or new ones? (JDM EF9)
mine has a zillion miles on it, out lasted the drain plug itself
Old Jul 11, 2002 | 12:04 PM
customx_'s Avatar
New User
use new ones, they only like 5 cents each.
acmoc
11
Dec 20, 2008 12:05 PM
ryanstev
Jan 10, 2007 04:51 PM
JMoneyJigga
May 28, 2004 10:07 AM
BeerBaron105
20
Jan 31, 2004 08:17 AM
shortyz
12
Dec 18, 2002 02:55 PM
