Stock rebuild, suggestions please..
Old Apr 11, 2008 | 05:19 PM
ocJDM4dr's Avatar
Default Stock rebuild, suggestions please..
I'm going to rebuild my GSR that been through 3 cars and had it for almost 4 years now. Two months ago it started to smoke at high revs, smell of burning oil also follows through when I come to a stop. knowing that it can be the rings or valves seals, I bought standard size piston rings, valve seals, and valve guides just to do a stock replacement. I also purchased ACL bearings, ARP rod bolts, standard size 81mm ITR pistons, and all new seals and gaskets. Engine its a JDM actual mileage not known, but I figure less than 90K.
My questions are;
1. Will I be able to change everything without having to do any crazy machine work? even though its recommended but short on cash right now.
2. Will the cylinder walls be fine by just replacing the rings with standard size again and not having to do an overbore or using overbore pistons? I'm planning to just honing the walls.
the engine was never raced or beat on it, just use as a daily. Thank you any suggestions or anyone done it this way before? thanks again
Modified by ocJDM4dr at 6:26 PM 4/11/2008
Old Apr 11, 2008 | 05:30 PM
slambedcivic's Avatar
Default Re: Stock rebuild, suggestions please.. (ocJDM4dr)
just get it honed.
ditch the ACL bearings. get oem honda bearings.
http://www.evans-tuning.com/te....html
check that link out. itll help you for sure!
Old Apr 11, 2008 | 05:31 PM
Default Re: Stock rebuild, suggestions please.. (slambedcivic)
just in case you were wondering why i posted the link: its so you know what to do for the honda bearings. youre able to pick a better size in relation to your clearances instead of getting the ACL's that are just std size.
Old Apr 11, 2008 | 05:36 PM
ocJDM4dr's Avatar
thanks man, I appreciate your time....
Old Apr 11, 2008 | 05:47 PM
ocJDM4dr's Avatar
the link is very informative and provides good details. The type of rebuild im talking about is without having to unmount the engine from the car, just to remove the oil pan and head. I see that they did a .5 overbore which is I'm afraid of.
Modified by ocJDM4dr at 7:08 PM 4/11/2008
Old Apr 11, 2008 | 07:10 PM
Default Re: (ocJDM4dr)
that setup is more for a race condition. its the exact same principle. if you get it honed, please take it to a shop. its not a lot of money. just extra time. better to be done right the first time than taking a risk of it being messed up
Old Apr 12, 2008 | 04:43 AM
ocJDM4dr's Avatar
I will have to take it to a shop for sure.....
Old Apr 12, 2008 | 05:55 AM
lol, why?
Old Apr 12, 2008 | 06:22 AM
ocJDM4dr's Avatar
Default Re: (slambedcivic)
caused they know their stuff, I won't have to deal with doing something wrong myself. The hardest part will be if they tell me that I will need an overbore once they inspect the walls.....
Old Apr 12, 2008 | 06:54 AM
EkFG's Avatar
Taking the bare block to a machine shop is A MUST the head too so it can get checked. Depending on the test they do on both they will tell you what needs to be done. But please PLEASE take it to a shop that has good feed back from others. Some shops hire people that dont know what the [freak] a ruler is, lol. but yeah They will tell you what really needs to be done if they are a good shop.hopefully you can get away with a hone and standard sizes if otherwise they will tell you if you have to go over size, take you crank shaft too and have that check. Expect to pay anywhere from 100-500 bucks depending what needs to get done or conditions of the motor.......If all is done well you can sleep well and not have to worry about **** happening.
Im doing the exact same thing you are but Im taking my **** IN FOR SURE!!
Old Apr 12, 2008 | 07:14 AM
ocJDM4dr's Avatar
Default Re: (EkFG)
true on that, the shop i dealt with in the past very well recognized for great work. As far as for the honing they charge $120...
Old Apr 12, 2008 | 05:32 PM
ocJDM4dr's Avatar
tttt..
XVNVX
Engine Machining & Assembly
Apr 24, 2017 01:00 PM
serjey15
Apr 10, 2014 06:19 PM
um3r
May 6, 2008 11:04 PM
the.hamburglar
Feb 2, 2006 06:02 AM
BLKCRX
Jul 24, 2002 03:40 AM
