how do i tell if its real?
i know this has been asked but i cant find it back. so if someone knows a good tread that would be great. anyways i am looking at a black 00 ITR in my area and wondering what to look for to make sure its the real deal. i have found this answer before but cant find it back
VIN, 5 lug, shaved side moldings, bigger brakes. There is a million things that differentiate a type r from a regular integra...things that can be swapped out would be interior, wing, etc...
anyone can "convert" a regular integra into a complete type r, but the VIN will always be the same no matter what...
the ls Vin would start with JH4DC4, but dont get confused cuz the GSR shares similar VIN numbers with the type r, being JH4DC2xxxxxx
Anyway, make sure all the VINs match up, and that the motor is healthy, look at the tranny too.
Speedo, interior parts, muffler, no sunroof, Rear Lower control arms are different, usually type rs have a reinforced subframe, making it possible to mount bigger sway bars without tearing the subframe....
look for a bigger sway bar and see if its mounted on the stock subframe...
Yup, lotsa different stuff, most can be bolted on another 'teggy. Here's a pic of the shell showing the R stuff,
(Thanks yoose Brooklyn Rob
Also no asphalt sound dampener on floor and trunk pan.
) Also no asphalt sound dampener on floor and trunk pan.
well since KBB does not work right now how much do 00-01 ITR's go for stock? the one i am looking at looks mint from the pics and says it has a clear title with 49K on it.
I don't think they made an RS in 2000, so no moonroof would be a big clue.
But yeah, VIN on the firewall and dash will read "JH4DC231..."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R »</TD></TR><TR><TD CLASS="quote">Kick the tire?</TD></TR></TABLE>
If the tire barks...then it's the real deal y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M »</TD></TR><TR><TD CLASS="quote">Wrong some gsr vins are dc2
the type r one will start as
JH4DC231
If it doesnt start like that is IT NOT a type r.</TD></TR></TABLE>
Yup
has to be DC231
JH4DC231
Yup
has to be DC231
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ultraspeed DC2 »</TD></TR><TR><TD CLASS="quote">easiest giveaway that cannot be copied from the type r is the rear subframe, just look at the bottom of the car, lie detector.</TD></TR></TABLE>
I'm surprised it took this long for this exact answer. Simple solution to anyones doubts of a car being a real R for not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrizzle »</TD></TR><TR><TD CLASS="quote">
has to be DC231</TD></TR></TABLE>
You might want to verify that it still has the ITR drive train...engine block should be stamped B18C5 and it should have an LSD stamp on the tranny. Check the VIN tag on the engine and tranny as well...if it matches the vehicle VIN, it is original. If there is orange paint on top of the B18C5 stamp, it is a OEM replacement. If the VIN plate has been drilled out or there are no VIN plates, I would do a little more research to make sure the engine isn't a stolen engine.
SkyliteCustomz
Sep 2, 2010 05:18 PM
John 07
Jan 3, 2007 06:46 AM
advert
Feb 19, 2006 06:12 AM
