no start
Old Apr 11, 2008 | 03:45 PM
slow88crx's Avatar
Default no start
I have a 94 ex coupe w/a jdm GSR in it. I fried my ecu the other day and replaced it. Unfortionately my car won't start. I checked all the fuses and replaced the fried ones. I replaced the distributer cap, rotor pin, and spark plug wires. I'm getting spark. It turns like it wants to start, it just never cranks. Any ideas?
Old Apr 11, 2008 | 03:58 PM
slambedcivic's Avatar
Default Re: no start (slow88crx)
could be 1000 things. have you checked for fuel. can you hear your fuel pump priming?
Old Apr 11, 2008 | 03:59 PM
Default Re: no start (slambedcivic)
and what fuses were fried?
Old Apr 11, 2008 | 04:02 PM
slow88crx's Avatar
I didn't even think to check the fuel pump. Some random ones. I can't exactly remember. I think there was one for my defrost. I can't really remember.
Old Apr 11, 2008 | 04:06 PM
when you turn your ignition to ON, listen for the humming in the rear of the car. if you cant hear it, get someone to turn the key on for you and get at the rear of the car and listen, if you cant hear it then, you have one of a few problems; bad fuel pump, bad main relay, more blown fuses, or a bad ECU.
Old Apr 11, 2008 | 04:09 PM
slow88crx's Avatar
thanks. I was going to upgrade my fuel pump as it was. I guess I won't be putting it off.
Old Apr 11, 2008 | 04:20 PM
well, dont just replace things if they arent bad because you could run into more problems. get the car running first, then upgrade it
ej84dr
Jun 16, 2010 05:20 AM
Jooleeus
13
Jul 20, 2008 08:46 AM
DumpedSi
13
Nov 29, 2006 09:17 PM
lawlerlaw
Nov 16, 2004 01:25 AM
JolToN49
Nov 20, 2002 11:41 AM
