[freak] car
ok today after i changed the ECU and Resistor box because my resistor box was no good so i was running the Fuel pump with a bridged cable...so today after 20 mins of driving the Car starting shake when i drive and throw lot of smoke...WHAT CAN THIS BE ???
Well judging by your very descriptive post I'm going to go out on a limb and guess you drive a 1988 dx that you did a mpfi swap on. Replace your distbributor that should fix it.
Seriously, you need to at least give some basic info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcmotor »</TD></TR><TR><TD CLASS="quote">ok today after i changed the ECU and Resistor box because my resistor box was no good so i was running the Fuel pump with a bridged cable...so today after 20 mins of driving the Car starting shake when i drive and throw lot of smoke...WHAT CAN THIS BE ???</TD></TR></TABLE>
What car--
What engine--
What ECU did you swap out--
What ECU did you swap in--
What have you done to your injectors and box etc---
Still OBD0 or did you go OBD1 or what---
What car--
What engine--
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by es.roadster »</TD></TR><TR><TD CLASS="quote">i think this dude is a joke</TD></TR></TABLE>
A not very funny joke. Either that or im still waiting for the punch line.
My car has been Fuel injection since i got it.88 honda Dx hatchback.. The ECU i changed was the same PM6
Engine: ZC
Resistor box i changed was from a SI EF9..
BUt i just put back on the old ECU and REsistor box and its fine now but it just smokes white that's it...
Engine: ZC
im curious why u think your resistor box was no good and what you mean when you say you ran your fuel pump with a bridged cable?
sounds like your car was getting starved of fuel
the white smoke sounds like a blown HG, which might have happened when you were running super lean
do a leakdown test
do a leakdown test
my resistor box was no good because i changed the main relay and after that the fuel pump was not getting any power . so yesterday after i replaced the good resistor box i turned off my car and it stay on why ? because i had the the extra wire hooked up too the 2 Yellow/black cable so that the fuel pump would work. So i took off the extra wire i added on there and the car started up good without the wire a added. but after 20 min driving car starting shaking. So the only way my car would run good is with the old resistor box and with the bridged wire i had on there. the White smoke happend to me long time ago but went away now it came back again but lot of smoke ...
