4x114.3 to 4x100 wheel adapters?
I've got a nice set of Rota Slipstreams leftover from my Integra just taking up space in my garage. Since the bolt pattern is different on the Accord, I was thinking of running some adapters so I could use my Rotas on the Accord. The best option would be to sell the 4x100's and get something that would fit but I thought I could save some $$$ and just run what I've got.
Anybody have any experience with those type of wheel adapters?
Problamatic at best with the adapter question. I would rather see a dual pattern rim before I'd consider adapters.
Adapters move the rim out a surprising amount (with all those attendant issues), and you may be dealing with fitment issues.
P
P
Yeah as far as finding them, you'll have to do some searching as others have said. I have spacers on my Accord (I use them to clear my calipers, but similar concept) I haven't had any problems but your going to want to be sure the hub, wheel and adapter are clean. Try to find some that are hub-centric, you can have balance problems otherwise. There will likely be more stress on the studs and slightly more stress on the wheel bearings but nothing you will need to worry about. I know H&R, Eibach and a few others make spacers, not sure about adapters, either ebay or a machine shop is your best bet.
HybridGSR1
Nov 25, 2003 09:04 AM
fangtl
Sep 25, 2003 12:44 PM
