wheel nob question....
ive recently been looking into getting some slicks ( i went boost) for my accord... and ive seen them on ebay in a 22" high 13xlike 7or8 i just dont know where to get a 13 inch rim that will work? what is the min. width i can run for like a 7 or 8 inch wide tire... thanks guys... sorry its such a tarted question...
You will need to use a 7~8" wide rim. Being that you have an Accord, you can't use Lenso's since they only come in 4x100 bolt pattern. Best bet would be a set of Bogart's or Weld's. Also, depending on the horsepower you are putting down, you may want to look at using a larger size slick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">You will need to use a 7~8" wide rim. Being that you have an Accord, you can't use Lenso's since they only come in 4x100 bolt pattern. Best bet would be a set of Bogart's or Weld's. Also, depending on the horsepower you are putting down, you may want to look at using a larger size slick.</TD></TR></TABLE>
sweet man... thanks.. i actually just stumbled on to bogarts stuff today... do you have any idea how much 2 rims usually go for cause i couldnt find any pricing... and what would be the best slick company/ size to run in your opinion... thanks agian..
A pair of Bogarts will usually run anywhere from $450-$600+ depending on the size and style that you want. If you are getting them brand new, be prepared for a wait, as they are made to order. In fact, I'm still waiting on a set that I ordered back in January. As for slicks, everyone has their own personal preference. For me, I've only used M&H slicks since I've been racing. I've had good performance with them, plus their customer service is top notch.
typeeg
Sep 9, 2005 06:29 PM
