B20 in an ej
Old Apr 11, 2008 | 10:48 AM
vtec0069's Avatar
Default B20 in an ej
Ok hey i have a rolling chasis a 1994 civic dx. Im going to put in a b20 in and I want like a complete list of the parts i need and what i need to do to make this work. I know this an obd1 car and the motor is od2, so if any help or anyone can point me in the right direction it would be great.
Old Apr 11, 2008 | 10:55 AM
slacks's Avatar
Default Re: B20 in an ej (vtec0069)
well.....
for starters the b20 block
-b series tranny with mounts (b16,ls, gsr, itr) since the b20 is too big.
-94-00 half shaft for b series
- hydro clutch (if you don't have one)
- manual starter
- tegra axles
- 94-00 teggy shift linkage
-inspection plate
-obd 1 ecu
btw.. the harness will plug directly into your obd1 chassis harness (for the most part)
uhm...................
can't think of anything else right now.
Old Oct 7, 2024 | 06:31 AM
Wylder's Avatar
you will also need a 99-00 crv dizzy if you don’t want to re wire your current dizzy
Old Oct 7, 2024 | 09:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
That doesn't quite work rookie... the wiring sequence is incorrect in the 8-pin plug AND there is no tach output signal in the plug. I suppose it could be modified in order to provide power to the distributor and a tach wire could be added to the ICM and run out of the distributor housing and connected to the second two-wire OBD-1 style plug, but this is NOT a plug-n-play solution.
OP, the proper plug-n-play solution, assuming that you are using the stock '94 Civic engine harness, would be a '94-95 Integra LS distributor.
sekoo_88
Feb 26, 2014 01:23 PM
Nameless RB26
14
Jul 29, 2009 06:10 PM
LSTEG98
Feb 7, 2007 07:08 PM
go2sleep
Apr 23, 2005 07:17 PM
