Suspension & Brakes Theory, alignment, spring rates....
integra wheel bearing issue, new bearing is too small
Old Apr 11, 2008 | 10:33 AM
JDogg's Avatar
Default integra wheel bearing issue, new bearing is too small
i have a 97 integra rs at the shop getting some new wheel bearings, turns out that no wheel bearing we order from anywhere fits. everyone for any civic/teg is too small, prelude/accord bearings are way too big.
the OD of hte bearing we pressed out is 79.10mm, the parts acura gives us are 78mm. .... we have no idea wtf is going on here and need to get this car out of here.
has anyone seen anything like this or have any idea why nothing fits.......
Old Apr 11, 2008 | 12:42 PM
Targa250R's Avatar
be professional
Default Re: integra wheel bearing issue, new bearing is too small (JDogg)
I don't know where you're getting parts from, but all of the wheel bearings I have for '94-01 Integra are 79mm, not 78 . . .
'94-01 Integra uses the same front wheel bearing as a '92-00 Civic EX (part no. 44300-S04-A02) and all '01-05 Civics (part no. 44300-S5A-008), so you may want to try at Honda instead of Acura.
Old Apr 11, 2008 | 03:35 PM
JDogg's Avatar
Default Re: integra wheel bearing issue, new bearing is too small (Targa250R)
hmm.. they keep giving us the s5a part number.. not sure if we have tried the s04 part.. ill check tomm
thanks for the info.
the bearings we pressed out are 79mm, the new stuff is always 78.. weird.
Old Apr 11, 2008 | 03:37 PM
raiden571's Avatar
92-95 civics have two different wheel bearings. an abs, and non-abs bearing. if you go to your local parts store, im sure they can get you the bearing you need.
ive ran into this issue before. and i think your rs is no abs, am i right?
Old Apr 11, 2008 | 04:30 PM
Targa250R's Avatar
be professional
The S04 and S5A parts are identical. If they won't work in the knuckle, then I don't know what to tell you. The Honda parts catalog lists 44300-S5A-008 as the correct part for a '97 Integra RS.
Old Apr 12, 2008 | 05:09 AM
JDogg's Avatar
yeah, they are all too small and fall right into the knuckle
Old Apr 12, 2008 | 08:57 AM
JDogg's Avatar
i ordered some s5a bearings from world pack and they fit right.. idk wtf acura was giving me, same part number and all...
Shooktd
11
Dec 3, 2011 09:16 AM
young_tuner
Feb 8, 2010 01:53 PM
ViZ
Feb 11, 2005 07:52 PM
Backmarker
Apr 22, 2003 04:59 AM
