Newbi valvetrain Q!
Since blowing my engine with Big cams I decided to do a more conservative setup.
I will be using my old block
12:1 CR 81.5 mm bores
W/ a Stock B16 head
I will be using CTR or Skunk2 Stg I cams and I cannot remember what valvetrain is needed.
If I remember correctly all I need to do is move the Inner intake springs to the exhaust side and install ITR inner springs. Is this correct? Also I wont be revving the engine past 84-8500k so I will also be using my stock retainers. Will this work? TIA
W/ a Stock B16 head
You want to move your intake side to your exhaust side, then get a new set of ITR intake valve springs. That should work with the stage 1 cams. If you don't mind me asking, what happened to your old set up?
.xcalibur.
Dec 12, 2007 12:26 PM
asocallocal
16
Sep 11, 2005 11:40 AM
screaminvtec
13
Jul 23, 2005 10:50 AM
StinkyTofu
Feb 8, 2002 10:17 AM
