complete b16 swap
Old Apr 11, 2008 | 04:08 AM
EK_kidd's Avatar
Default complete b16 swap
I got a b16 with tranny and ecu not to long ago.I want to swap it in my 99 ek.. But I dunno all the things I need to make my swap complete. Like I kno I need mounts, wire harness,and axels.. but is that all? Will I loose my a/c doing a swap?
Old Apr 11, 2008 | 05:32 AM
b18 hatch mike's Avatar
Default Re: complete b16 swap (EK_kidd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_kidd &raquo;</TD></TR><TR><TD CLASS="quote">I got a b16 with tranny and ecu not to long ago.I want to swap it in my 99 ek.. But I dunno all the things I need to make my swap complete. Like I kno I need mounts, wire harness,and axels.. but is that all? Will I loose my a/c doing a swap?
no you will not loose a/c
but i took mine out when i did my swap
Old Apr 11, 2008 | 05:38 AM
slo_hatch's Avatar
you can get most of your parts from an si. and you will need to wire in the vtec if you do not already have it wired. you can use si mounts, wiring harness from the si (or just wire in your vtec), and you can use 99-00 si axles...at least i believe. you will need the shift linkage also. i cant think of anything else you will need. good luck.
Old Apr 11, 2008 | 07:11 AM
EK_kidd's Avatar
Default Re: complete b16 swap (slo_hatch)
thanks
Old Apr 11, 2008 | 07:17 AM
Ej Girl's Avatar
Could also use 94-01 Integra axles and motor mounts, if its easier to find then Si parts. If you have a dx model or one that does not have vtec, remember to get a body harness that has vtec on it or you will have to wire vtec yourself. Its not hard to wire it yourself, it just makes your swap look cleaner, since mine has some extra wires hanging around in your engine bay like mine .
Old Apr 11, 2008 | 07:37 AM
EK_kidd's Avatar
Default Re: complete b16 swap (Ej Girl)
naw i got an ex. and it comes with vtec already.. so i gues i dont have to do any wireing on that
Old Apr 11, 2008 | 07:41 AM
Ej Girl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_kidd &raquo;</TD></TR><TR><TD CLASS="quote">naw i got an ex. and it comes with vtec already.. so i gues i dont have to do any wireing on that</TD></TR></TABLE>
yep pretty much a plug and play
Old Apr 11, 2008 | 08:02 AM
EK_kidd's Avatar
i hope i dont mess up
93WhiteHatch
Jun 18, 2007 01:48 PM
Beau Gotti
Southeast (Sales)
Jan 7, 2007 04:01 PM
sol_1320
Jul 16, 2005 09:33 PM
