doing a motor swap in a 96 ek. need help with mounts
Old Apr 11, 2008 | 12:14 AM
asocallocal's Avatar
Default doing a motor swap in a 96 ek. need help with mounts
i have a stock dseries motor still in the car. can i use all the d-series mounts to get a b16 swap in my car? what i can use or what will i need to get?
Old Apr 11, 2008 | 12:41 AM
SirRevvs's Avatar
Default Re: doing a motor swap in a 96 ek. need help with mounts (asocallocal)
you need 99-2000 civic si block mount (the one that bolts directly to the driver side of the engine block) and 99-2000 civic si rear trans bracket. The top trans bracket from the d-series can be re-used along with the driver side hydro framerail mount and fraimrail mount bracket. If you want A/C you will need a 99-00 civic si a/c bracket. You can use any 94-01 b-series front trans torque mount.
Old Apr 11, 2008 | 06:22 PM
so i need 99si:
block mount
rear tranny bracket
a/c bracket ( for A/C only)
bseries front tranny torqe mount.
so i will i need 4 total and reuse some of the old deseries mounts? is that correct?
Old Apr 11, 2008 | 06:26 PM
ekb16's Avatar
didnt i just see this post eariler today?
Old Apr 11, 2008 | 07:06 PM
idk. let me know if im correct. what mounts is needed if i have a dseries swap still in the car. i need go buy it asap
Old Apr 11, 2008 | 09:37 PM
ek4_b16a's Avatar
i'd suggest getting an aftermarket driver side motor mount made for your civic...you'll need the si rear L bracket...and that's it...well ofcourse you'll need the axles and shift linkage...could look at the FAQ's too....SEARCH next time but gl on your future swap
Old Apr 11, 2008 | 10:28 PM
Default Re: doing a motor swap in a 96 ek. need help with mounts (ek4_b16a)
thats whats up right there. good looking out man. all i need is:
and si rear L bracket.
thats was the answer i was lookin for.
GrimeyAssLos
11
Feb 27, 2012 09:56 AM
slowazz97civic
Jul 20, 2005 04:41 PM
SyDuck
Jan 28, 2005 06:59 PM
ApexiChild
Nov 29, 2004 02:13 PM
GOLDBERG
Nov 15, 2003 06:37 AM
