can i make my dx have power windows??
Old Apr 10, 2008 | 10:48 PM
civic4nick's Avatar
Default can i make my dx have power windows??
if i got new door panels with switches, could i make it work? or would it require extensive wiring?
Old Apr 10, 2008 | 11:54 PM
TOO MUCH TORQUE's Avatar
nope, its pretty much plug and play
Old Apr 11, 2008 | 12:01 AM
GSRcivicDX's Avatar
Default Re: can i make my dx have power windows?? (civic4nick)
I put power windows in my dx from an si, took a little time to figure out what wires did what, but from what I remember I only had to run power to the driver side switch, then ran 2 wires from the drivers side switch to the passenger side switch and hook up the motors to the switches. Its been about 7 years since I did this but no problems with it since, so if you have the patience it can be done. I could probably be done pretty easily with help from a wiring diagram.
Old Apr 11, 2008 | 12:02 AM
GSRcivicDX's Avatar
Default Re: (TOO MUCH TORQUE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">nope, its pretty much plug and play</TD></TR></TABLE>
My EK only had 2 wires in the door for the speakers
Old Apr 11, 2008 | 11:26 AM
civic4nick's Avatar
what im wondering is if it has the hookups for it already? if so, all i do is switch the door panels out and plug em in? cuz if thats the case, i will switch out my door panels...
Old Apr 11, 2008 | 12:34 PM
dognutz's Avatar
Default Re: (civic4nick)
No it's not plug and play unless you grab a floor harness, but it not difficult with out the floor harness if you can solder. See if this link helps.
http://repo.jackmoves.com/v/erik/albun31/albun42/
Old Apr 23, 2008 | 03:28 PM
BIG_WILL's Avatar
Default Re: can i make my dx have power windows?? (GSRcivicDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRcivicDX &raquo;</TD></TR><TR><TD CLASS="quote">I put power windows in my dx from an si, took a little time to figure out what wires did what, but from what I remember I only had to run power to the driver side switch, then ran 2 wires from the drivers side switch to the passenger side switch and hook up the motors to the switches. Its been about 7 years since I did this but no problems with it since, so if you have the patience it can be done. I could probably be done pretty easily with help from a wiring diagram.</TD></TR></TABLE>
what gauge wired did you use?
did you run a ground to the switch?
SO basicly you took power to the d. side switch and connected the motor then took a power to the p. side and a wire to be able to control the p. side window?
Old Apr 25, 2008 | 01:28 PM
GSRcivicDX's Avatar
Default Re: can i make my dx have power windows?? (BIG_WILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIG_WILL &raquo;</TD></TR><TR><TD CLASS="quote">
SO basicly you took power to the d. side switch and connected the motor then took a power to the p. side and a wire to be able to control the p. side window?</TD></TR></TABLE>
From what I remember I used 12g wire, I found the inner door harness and jam harness off a car with power windows . I only remember having to run 3 wires. 1 was a power to the drivers side switch then 2 wires from the drivers switch over to the passenger switch. I believe the polarity reverses on the 2 wires from the drivers switch allowing the passenger window to go up or down. If I remember right the pass side motor only has 2 wires and depending how you connect power/ground to these 2 wires controls which way the window rolls.
j4s0n1337
Apr 4, 2012 07:28 AM
icedaccord19
Apr 15, 2011 05:08 AM
Windwalker
Apr 9, 2009 10:14 AM
92ehatch
Nov 24, 2005 02:53 PM
