DA Integra: Starting up and then turning off after being on for a while prior (overheat?)
Old Apr 10, 2008 | 10:15 PM
KillerElfboy's Avatar
Default DA Integra: Starting up and then turning off after being on for a while prior (overheat?)
Hey, i had this problem when i was getting gas but i think it was becuase i had been running the car and only gave a two minute interval to turning it on again.
The car turns on and the RPMs rise then fall but dont stop and the car dies. Could this be overheating? I know the head was resurfaced sometime ago for the car, i heard that gives some indication but i dont know. Anyone know how to fix this or what i can do? Once i get it moving it seems to be ok but i dont wanna risk anything getting worse
i drive a 1991 RS hatchback. Currently my exhuast is bobbling at the flange so i pretty much dont have an exhuast its just hanging there if that helps
Old Apr 11, 2008 | 06:40 AM
bettsbanger's Avatar
Default Re: DA Integra: Starting up and then turning off after being on for a while prior (KillerElfboy)
maybe you just need to adjust your idle
Old Apr 11, 2008 | 10:31 AM
Default Re: DA Integra: Starting up and then turning off after being on for a while prior (bettsbanger)
it never happens first thing in the morning, only after its recently been turned off.
How do i adjust my idle? What should it be idling at startup becuase it is up around 2k rpms when i start it until iv been drive down the street then it lowers to normal eventualy
Old Apr 12, 2008 | 10:42 AM
KillerMTRsports's Avatar
check your throttle cable....if you adjust your idle till about one then you should be fine
acuralovar
Feb 21, 2011 09:34 PM
Volko
Oct 20, 2008 11:58 PM
TypeRKoncepts
Mar 4, 2005 04:24 PM
preluder
Jul 25, 2003 11:57 AM
