Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
add hp to 08 civic si?
Old Apr 10, 2008 | 09:55 PM
sam139901's Avatar
Default add hp to 08 civic si?
I'm getting an 08 si and I'm a little low on cash from buying the car.
I was wondering what would be good to add up a little more hp
without having to dig too deep into my pockets.
I'm going to add an amp and a base just for now, but
I'm thinking of spending around 300$ to 500$ for the engine.
I know the k20 is a pretty easy engine to boost up. So what would be good?
Thanks!
Old Apr 10, 2008 | 10:18 PM
100miles+'s Avatar
From: In Diamond Bar, CA Brake Boosting like a Mother Focker!
Default Re: add hp to 08 civic si? (sam139901)
DC Race header or the usual intakes?
PS..... use the search button!!!!!!!!!!!!!!!!! Or atleast scroll down a little!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 11, 2008 | 06:49 AM
jaepalm's Avatar
The first couple mods to start with are an intake (cold air preferably, just watch out for big puddles!!!) then exhaust; in that order.
This will basically let the car breath and give you around 10-15 added horses combined. They sell "hydroshields" which are basically just fancy socks that you put over the intake to REDUCE the chance of water being sucked into it and, thus, f-ing your s up.
Old Apr 11, 2008 | 07:33 AM
xkrntamax's Avatar
intake - exhaust - header - ecu - cam shaft? - turbo or supercharer
Old Apr 11, 2008 | 08:19 AM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
Default Re: add hp to 08 civic si? (xkrntamax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkrntamax &raquo;</TD></TR><TR><TD CLASS="quote">intake - exhaust - header - ecu - cam shaft? - turbo or supercharer</TD></TR></TABLE>
Intake, exhaust, TB spacer, race header, tires, suspension, reflash, brake pads in that order.
Old Apr 11, 2008 | 01:15 PM
ChargedSI's Avatar
Ok, if you really want to add some HP, than add 2 additional squirrels under the hood. This is a little tricky because you will need to lash all the squirrels together so they run on the wheel together. You might need to increase the size of your radiator so they have enough water to drink.
Honestly, the lists provided above are the standard starters. Intake, Exhaust, maybe an IM Gasket. Depending on what you go with, these will run you about $800.00. After that most people do a header, and Hondata and/or suspension. If you still want more you are looking at boost. Brakes should be your last upgrade since the stock brakes are pretty damn good to begin with.
Good luck
Old Apr 11, 2008 | 06:48 PM
i-VTEC_DOHC's Avatar
i have a dcrh on the way right now =]]
i got an 08 si as well
Old Apr 11, 2008 | 07:32 PM
RICO_'s Avatar
NO MERCY!
Here's a thought......
If you're really serious about adding HP to your ride.....then DITCH THE SUB AND AMP INSTALL.
Sacrifice man.
A good amp and sub install with necessary wiring and the sub box will run you at least 200-300 bucks....maybe just for parts alone if you get something halfway decent.
Your choice bro!
Old Apr 11, 2008 | 07:40 PM
Default Re: add hp to 08 civic si? (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">Here's a thought......
Sacrifice man.
Your choice bro! </TD></TR></TABLE>
very true. u can get an injen sri for that price. and maybe a set of spark plugs also would be pushin it a lil bit
Old Apr 12, 2008 | 12:25 AM
FG2quick's Avatar
Sacrifice man.
Exactly, I could not have said it any better myself. Not only are you spending $$$ with no gain in hp, you are adding weight. so you do the math. stock sound isnt that bad, plus i think its dumb when all these cars have nothing but bass and rattle the cars next to them and have no power to move thier 16 12" subs. i dont know, just my .02
Old Apr 12, 2008 | 04:19 AM
RICO_'s Avatar
NO MERCY!
Default Re: add hp to 08 civic si? (i-VTEC_DOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i-VTEC_DOHC &raquo;</TD></TR><TR><TD CLASS="quote">
very true. u can get an injen sri for that price. and maybe a set of spark plugs also would be pushin it a lil bit</TD></TR></TABLE>
Stock spark plugs are NGK Iridium plugs. Doesn't get much better than that.
Old Apr 12, 2008 | 12:09 PM
DiMpL3s.'s Avatar
x2
Old Apr 16, 2008 | 10:57 PM
dj12oclock's Avatar
after all that modding.. how much hp are you adding?
Old Apr 17, 2008 | 08:36 AM
kkilo's Avatar
Default Re: add hp to 08 civic si? (DiMpL3s.)
Sacrifice man.
QFT.
KadenB
May 18, 2018 07:56 PM
dj12oclock
21
Feb 5, 2009 09:43 PM
llckll
26
Jul 2, 2007 08:15 PM
DELsolsKICK
28
Nov 6, 2002 10:33 AM
gregv
Jan 31, 2002 01:59 PM
