Rand0m Starting Issue...
Old Apr 10, 2008 | 06:19 PM
oc_civic's Avatar
Default Rand0m Starting Issue...
on occasion..
i will go to start my car mostly after its sat a while..
and i get one single click no start
i will repeat this several times and the car does nothing
judging by the volt meter battery is taking a charge and holding it fine it appears the car is getting juice...
then it will just eventually start
car runs fine
appears to happen less through the day
any input thanks..
Old Apr 10, 2008 | 06:33 PM
Former User's Avatar
Default Re: Rand0m Starting Issue... (oc_civic)
Check whether the ground wire located on the thermostat housing is loose or corroded. Do the same for the battery and starter wires.
samvilay
May 11, 2010 04:36 PM
silentkid
Mar 3, 2010 11:59 AM
lawlss
15
Sep 14, 2009 10:23 PM
1993gsrcivic
Dec 2, 2008 10:30 AM
Ph0eNix
Dec 15, 2005 11:58 AM
