tranny reseal?
Old Apr 10, 2008 | 01:08 PM
slo_ej8's Avatar
Default tranny reseal?
how hard is it to reseal a tranny case that has been taken apart?
should i just go to a shop and have them do it? i have hondabond at home..
Old Apr 10, 2008 | 01:24 PM
slo_ej8's Avatar
Default Re: tranny reseal? (slo_ej8)
bump. i need to know this.
Old Apr 10, 2008 | 01:55 PM
NOFX's Avatar
H-T White Ops
As long as it's all together correctly... sealing it is easy.
Old Apr 10, 2008 | 02:05 PM
slo_ej8's Avatar
Default Re: (NOFX)
well its been put back together without a seal.. do i have to open it up again and seal it?
Old Apr 10, 2008 | 02:32 PM
slo_ej8's Avatar
Default Re: (slo_ej8)
bump
Old Apr 10, 2008 | 02:42 PM
pdiggitydogg's Avatar
There needs to be a seal around the two halves or it will leak.
Yes, you need to undo all the bolts and place a bead of rtv where the halves come together.
No sealant is needed between the block and transmission
Old Apr 10, 2008 | 02:44 PM
slo_ej8's Avatar
Default Re: (pdiggitydogg)
ive never worked with transmissions before.. is this an easy jo? or am i better off taking it to a shop?
Old Apr 10, 2008 | 02:54 PM
Transmissions are not as difficult to work with as everyone makes them out to be.
If you can undo the housing bolts, you can reseal it. The most confusing part about it will be torquing them in the right order and to the right spec....which is simple enough....once you get a manual.
Its really just as simple as the 2nd sentence I wrote in the previous post:
"undo all the bolts and place a bead of rtv where the halves come together."
If the trans is already on the car-
If a shop did it, make it their problem. They screwed up.
If you did it, then you already know how to drop the trans.
Old Apr 10, 2008 | 02:56 PM
slo_ej8's Avatar
thank you
chenlenglor
Jan 6, 2010 11:51 AM
Lmgrcivic
Oct 10, 2005 07:43 AM
team703
Apr 23, 2004 03:08 AM
navin
Mar 18, 2002 11:28 AM
