SOME POPPING NOICE COMING FROM THE FRONT!!! NEED HELP!!!
OK HERE IS THE DEAL I GOT A TYPE S 04, THIS THING JUST STARTED TO HAPPEN, EVERYTIME IMA PARK MY CAR IN MY HOUSE WHEN I GO IN REVERSE AND I TURN THE WHEEL TO THE LEFT OR RIGHT THERES ALWAYS SOMETHING THAT POPS. SOUNDS LOUD LIKE WHEN YOUR AXLES ARE [freak]ED UP BUT THE AXLES ARE FINE I ALREADY CHECK THEM.... SO DOES ANY BODY GOT AN IDEA..??? ANY THING WOULD BE HELPFUL THANKS...
I actually am having the same thing happen. I recently replaced an upper ball joint and lower ball joint on the opposite side.
I think it may be the lower ball joint that i didn't replace :/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonReggeaton »</TD></TR><TR><TD CLASS="quote">damn yea cuz my homie told be abuot some braket something i forgot the name haha> but damn i need my car
I still drive mine
</TD></TR></TABLE>I still drive mine
If you're running aftermarket suspension, that's probably the cause.
Also, try a search. We've covered this several times as this noise is not uncommon.
Could be a number of things--you'll have to investigate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">If you're running aftermarket suspension, that's probably the cause.
Could be a number of things--you'll have to investigate.</TD></TR></TABLE>
Why would aftermarket suspension cause this noise?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ »</TD></TR><TR><TD CLASS="quote">
Why would aftermarket suspension cause this noise?</TD></TR></TABLE>
Not correctly installed front struts/tophats/springs (which is easy to do on these cars), something isn't tight, swaybar is slipping (which gets loosened when suspension is installed), etc.
Basically, installer error.
And some suspension just clunks (i.e Ground Control or any other sleeved coilover).
this is a common problem on rsx's even with stock suspension
i actually had this problem when i was stock
slapped on a set of eibachs and the problem was gone
not sure how but i'm glad i got rid of it
