mini me swap question.
Old Apr 10, 2008 | 08:54 AM
kojack_0's Avatar
Default mini me swap question.
i have a d15b7 block with a d16z6 head in it.
when everything is said and done.
meaning everything is back into place with the z6 head on.
do i have to advance/retard the timing?
Old Apr 10, 2008 | 09:04 AM
kojack_0's Avatar
Default Re: mini me swap question. (kojack_0)
i know someone did a mini me before!
anyone?
bump.
Old Apr 10, 2008 | 10:13 AM
kojack_0's Avatar
16 views no reply.
cmon ht.
bump.
bump.
Old Apr 10, 2008 | 10:39 AM
teal_dx's Avatar
just be sure everything is at TDC (top dead center) and then check the ignition timing
Old Apr 10, 2008 | 12:17 PM
ddd4114's Avatar
Default Re: mini me swap question. (teal_dx)
Use a y7/y8 cam gear or an adjustable gear. Then you won't have to worry about this.
Old Apr 10, 2008 | 11:23 PM
kojack_0's Avatar
Default Re: mini me swap question. (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">Use a y7/y8 cam gear or an adjustable gear. Then you won't have to worry about this.</TD></TR></TABLE>
what do you mean?
not to sound mean.
but what would that do?
Old Apr 11, 2008 | 12:47 AM
SirRevvs's Avatar
The timing is "1/2" tooth off with the Z6 cam gear you won't be able to get it right. You must either use a Y7 cam gear which will fix the problem and correct it to stock timing or get an adjustable cam gear.
Old Apr 11, 2008 | 06:38 AM
ddd4114's Avatar
Default Re: mini me swap question. (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">The timing is "1/2" tooth off with the Z6 cam gear you won't be able to get it right. You must either use a Y7 cam gear which will fix the problem and correct it to stock timing or get an adjustable cam gear.</TD></TR></TABLE>
Old Apr 11, 2008 | 07:30 AM
kojack_0's Avatar
well im following the mini me swap that BauleyCivic wrote up.
it says that the z6 cam gear does have an extra tooth.
with that, he said to use the z6 timing belt.
dont know if that would do anything about timing.
if anything, i cant use the cam gear from the b7?
since y7 is non-vtec?
Old Apr 11, 2008 | 08:17 AM
ddd4114's Avatar
The y7/y8 gears are offset by 1/2 tooth. It has nothing to do with originating from a VTEC or non-VTEC head. You should use a z6 timing belt regardless of the gear you have.
Old Apr 11, 2008 | 08:20 AM
team_sol06's Avatar
what distributor do u got to use
Old Apr 11, 2008 | 08:22 AM
ddd4114's Avatar
Default Re: (team_sol06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team_sol06 &raquo;</TD></TR><TR><TD CLASS="quote">what distributor do u got to use</TD></TR></TABLE>
Ideally a z6 distributor.
Old Apr 11, 2008 | 08:29 AM
team_sol06's Avatar
i cant use my d15b7 one
Old Apr 11, 2008 | 08:31 AM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team_sol06 &raquo;</TD></TR><TR><TD CLASS="quote">i cant use my d15b7 one</TD></TR></TABLE>
You can if you hack up the frame.
Old Apr 11, 2008 | 08:32 AM
kojack_0's Avatar
Default Re: (ddd4114)
yeah a z6.
Old Apr 11, 2008 | 08:33 AM
team_sol06's Avatar
just like u did or what,is it because it dont line up
Old Apr 11, 2008 | 08:49 AM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team_sol06 &raquo;</TD></TR><TR><TD CLASS="quote">is it because it dont line up</TD></TR></TABLE>
Right.
Old Apr 11, 2008 | 09:22 AM
kojack_0's Avatar
im pretty sure you can still use the b7 distributor, the bolts just wont line up.
Old Apr 11, 2008 | 09:26 AM
ddd4114's Avatar
Default Re: (kojack_0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kojack_0 &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure you can still use the b7 distributor, the bolts just wont line up.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">You can if you hack up the frame.</TD></TR></TABLE>
austen95
Mar 12, 2018 06:55 PM
EGcivicBoy
Oct 9, 2008 10:28 AM
ej2vtec
Nov 30, 2006 05:33 PM
RNPoo7
Nov 21, 2006 06:20 AM
