install motor from bottom
Old Apr 9, 2008 | 10:43 PM
JmurGSR98's Avatar
Default install motor from bottom
Anyone know if I can install a motor in from the bottom, without using a cherry picker? Its for a 98 GSR. And can it be done by myself?
Old Apr 10, 2008 | 12:38 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: install motor from bottom (JmurGSR98)
If your hercules! I did it from under the car but a cherry picker was a must!
Old Apr 10, 2008 | 01:31 AM
JmurGSR98's Avatar
Default Re: install motor from bottom (wunfstgsr)
So you placed the engine under the car while it was on jacks, lower the car onto the engine and used the cherry picker to raise it?
Just want to know the easiest way to do this by myself.
Old Apr 10, 2008 | 01:39 AM
schmiddr2's Avatar
If you have a good flat hard surface you can do it yourself. Go buy 4 small low profile caster wheels. A 3x3 piece of thick plywood. Make a cart, put the motor on it, and roll it under the car. Jack up the cart. gl
Old Apr 10, 2008 | 01:46 AM
JmurGSR98's Avatar
Default Re: install motor from bottom (schmiddr2)
Thanks.
Old Apr 10, 2008 | 10:58 AM
wunfstgsr's Avatar
Loved
Community Favorite
"So you placed the engine under the car while it was on jacks, lower the car onto the engine and used the cherry picker to raise it?"
Exactly!, nice and easy
Old Apr 10, 2008 | 11:10 AM
IZEONLI's Avatar
i do the same thing when i swapped in my usdm h22 for a jdm h22 in my lude. but i work in a dealership so it was easy for me. also i have friend who take the whole front end of the car off and just walk the engine out. GL.
ranta18
Jan 18, 2008 10:45 AM
tkevin07
Aug 31, 2006 03:03 PM
KingJeff
May 11, 2005 02:26 PM
faSHOwidIT
Apr 8, 2005 04:32 AM
margaflow
11
Sep 29, 2001 08:30 PM
