00 si vibration on accel..
Old Apr 9, 2008 | 08:30 PM
418whpturboD's Avatar
Default 00 si vibration on accel..
ok so my gfs si hes a virbration only when acceleration in 1st-3rd gear.. only when around half throttle.. it has brand new wheels and tires.. had the re-balanced, hub centric rings put on wheels, new tie rods, align ment, and new motor mounts.. i can not figure out what is wrong..
Old Apr 9, 2008 | 08:33 PM
JDMEGKOUPE's Avatar
Default Re: 00 si vibration on accel.. (418whpturboD)
sounds like your axles are bad
Old Apr 9, 2008 | 08:34 PM
bubblebrain's Avatar
whats the vibration like? does the steering wheel shake? does it do it right as the car starts moving? most likely there is something bent. has she run into any ditches or curbs lately? have the shop recheck the alignment.
Old Apr 9, 2008 | 08:43 PM
Default Re: 00 si vibration on accel.. (bubblebrain)
we just got alignment.. it starts shaking around 20mph, and it like the whole car shakes .. its not a horrible shake but vary notice able
Old Apr 10, 2008 | 08:19 PM
bump
Old Apr 13, 2008 | 09:34 PM
any one
Old Apr 13, 2008 | 10:29 PM
EKway2low's Avatar
HEY I HAVE THE SAME PROBLEM ON MY 00 CIVIC SI I PUT BRAND NEW AXLES TIE RODS NEW FULL COILOVERS AND HAD IT ALIGNED LIKE 3 TIMES AND IT JUST DOESNT GO AWAY AND ITS VIBRATES ONLY AT AROUND 20-40 MPH BASICALLY JUST LIKE YOURS DOES.. SO IF U EVER FIGURE IT OUT LET ME KNOW ...
Old Apr 23, 2008 | 08:59 AM
Default Re: 00 si vibration on accel.. (EKway2low)
bump... still can't find the problem...
Old Apr 23, 2008 | 09:12 AM
H22Ej1's Avatar
Shenanigans
if a shop did the work take it back and tell them the issue and have them deal with it, otherwise check your suspension, tie rods, bearings, axles, etc and have your wheels rebalanced
Old Apr 24, 2008 | 08:48 PM
Default Re: 00 si vibration on accel.. (H22Ej1)
i had new tie rods put on.. wheels have been rebalanced, checked the axles, changed suspension, had alignment done twice, checked motor mounts, chnged tourqe mounts, changed wheels around, and it still vibrates under acceleration.. im out of ideas.. it didnt do it untill we lowered the car.. now its on stock **** and still does it..
wk9k
Aug 18, 2015 12:28 PM
em1 legend
Mar 9, 2014 08:53 PM
superg6819
Feb 20, 2006 10:27 PM
XX Boosted Si XX
Feb 5, 2005 05:37 PM
