I need a clutch replacement write up
I've tried searching and it only gave me results leading to for sale ads. I'm planning to replace my clutch and am looking for a good write up that can guide me through the process. thanks.
Its not too hard. I went into my first clutch replacement on a Honda blindly. My mentality was just to remove any and everything standing in my way of getting the tranny out. After that, its just a matter of unbolting the PP from the flywheel and replacing the clutch and PP. I'm sure there's a writeup somewhere for it though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chicows18 »</TD></TR><TR><TD CLASS="quote">REMOVAL & INSTALLATION
CLUTCH ASSEMBLY
Removal
1. Disconnect negative and positive battery cables. Remove battery base and air cleaner and tube assembly.
Disconnect starter and transaxle ground cables. Remove engine harness clamp. Disconnect speedometer
sensor connector. Disconnect back-up light switch.
2. Remove clutch pipe bracket and clutch release cylinder. Drain transaxle fluid. Remove starter. Remove
engine and right wheelwell splash shields. Remove header pipe. Separate lower control arms from ball
joints. Remove right radius rod. Using 2 large screwdrivers, pry both drive shaft inner CV joints out of
transaxle. Protect drive shaft ends.
3. Remove header pipe bracket. Remove shift and extension rods. Remove splash guard and front stopper
bracket. Install hoist at proper places on engine, and lift engine slightly to unload engine mounts.
4. Place a jack under transaxle, and slightly raise jack to take weight off transaxle mounts. Remove front
transaxle mount. Remove rear transaxle mount bracket. Remove side transaxle mount. Remove transaxle
housing mount bolts. Pull transaxle away from engine, and remove transaxle.
Installation
Before installation, use NEW circlips on inboard side of drive axle shafts. Use NEW self-locking nuts on front
end of radius rod and header pipe bracket. Use NEW through bolt on firewall side transaxle mount. To install
transaxle, reverse removal procedure.
TORQUE SPECIFICATIONS
Application Ft. Lbs. (N.m)
Battery Base Mounting Bolts 16 (22)
Flywheel Housing-To-Engine Bolts 47 (65)
Flywheel-To-Crankshaft Bolt 89 (120)
Front Wheel Lug Nuts 81 (110)
Intake Manifold Bracket Bolts 16 (22)
Intermediate Shaft Support Bolt 28 (39)
Master Cylinder Mounting Nuts 14 (19)
Pedal Adjuster Lock Nut "C" 13 (18)
Pressure Plate-To-Flywheel Bolts 18 (25)
Rear Mount-To-Transmission Bolt 47 (65)
Release Cylinder-To-Housing 16 (22)
Speed Sensor Mounting Bolts 14 (19)
Starter Mounting Bolts 33 (45)
INCH Lbs. (N.m)
Pedal Adjuster Lock Nut "A" 89 (10)
Pedal Adjuster Lock Nut "B" 89 (10)</TD></TR></TABLE>
i think thats from the accord forum, although i can't imagine a b series would be that different. if you feel that it is http://www.team-integra.net/se...D=957 that otta do it!
CLUTCH ASSEMBLY
Removal
Installation
INCH Lbs. (N.m)
mechmunkee3
Feb 15, 2008 02:24 AM
